53 block
Old May 28, 2009 | 01:19 PM
Tejas TJ's Avatar
53 block
Can you find out if a truck has a 53 block by look at he engine #, or do you have to find it located on the side of the block?
Old May 28, 2009 | 01:29 PM
Dr. Evil's Avatar
You have to crawl under the truck and look at the block
Old May 28, 2009 | 01:31 PM
CTD NUT's Avatar
I doubt the engine serial number would somehow have that info. The "53" is a casting pattern number - a number used to identify a specific pattern used by the foundry. It was not meant to specifically identify a block. Regardless, it would be much quicker to just get under the truck and shine a flashlight below the IP and look for the number....you can't really miss it. The number text is about 1.5" tall.
Old May 28, 2009 | 09:37 PM
Bradleysram's Avatar
please fogive my ignorance but whats the IP
Old May 29, 2009 | 01:50 AM
Dr. Evil's Avatar
IP = Injector Pump.
And the #53 casting can be on the drivers side or BOTH sides:
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
Old May 29, 2009 | 08:12 AM
high bid's Avatar
Just a note, not all 53 blocks have been found to have the "thin" cyclinder/cooling wall. I believe it's those cast in Brazil. BUT, there's really no way to check unless you pop out the freeze plugs in the area prone to cracking and check the thickness.
Old May 29, 2009 | 11:02 AM
CTD NUT's Avatar
Proof?
#53 is one pattern from one foundry.
Old May 29, 2009 | 11:54 AM
Honda Hunter's Avatar
If your reffering to the purdy red truck in your other post that you are thinking about trading for, the 99-early 01 only had the 53 block, so that 02 shouldnt have it.
Old May 29, 2009 | 02:53 PM
CTD NUT's Avatar
98 - 01 could have the 53.
Old May 30, 2009 | 11:19 AM
Tejas TJ's Avatar
I was looking at the '99 too.
Old May 30, 2009 | 01:13 PM
high bid's Avatar
As I stated, others on DTR have posted info stating the block wall thickness has been found to be "thicker" on some 53 blocks vs others. I do understand your point.
Old May 30, 2009 | 03:21 PM
rich's Avatar
it will either crack or not. The high mile 98.5 had the 53 it was overworked and had added power never a problem
Old May 30, 2009 | 04:15 PM
J BODY's Avatar
.......or it could have been ground off, hit with a DA, and painted shiny black to match the rest of the engine.
Old Jun 1, 2009 | 07:25 AM
CTD NUT's Avatar
Scary but true.
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
