241DLD to 241DHD ???
Old May 26, 2009 | 09:50 PM
skidooer76's Avatar
Question 241DLD to 241DHD ???
if the t-case comes out of a auto truck will it be a direct replacement or not???
Thanks for the info in advance
Old May 27, 2009 | 07:18 AM
skidooer76's Avatar
no one has done this swap?
Old May 27, 2009 | 07:53 AM
patdaly's Avatar
I think there are subtle driveshaft length differences, other than that I think it is a direct bolt in.
Both of mine are DHDs so I have no experience with a DLD.
Old May 27, 2009 | 01:06 PM
Southern Pride's Avatar
for some reason i think that the input gear has a different number of teeth. i k when i did my tranny swap from auto to man, i had to change out the input gear from the 27 spline to a 29 spline. other than that i cant remember what the differences are. ive got a parts book at home and can take a look at it and get back on here tomorrow on the differences.
Old May 27, 2009 | 04:17 PM
patdaly's Avatar
Autos should have a 23 spline for both DHD/DLD, Manuals should be 29 for both.
Old May 28, 2009 | 10:50 AM
thats right pat. i forgot the exact spline count on the auto/ man shafts. do you know the difference in the dhd/dld t-cases. just curious for my own knowledge. i forget.
Old May 28, 2009 | 12:09 PM
patdaly's Avatar
I think the tailhousing on the DHD is about an inch longer.
Old May 30, 2009 | 08:32 AM
skidooer76's Avatar
so I was thinking of switching the tailhousings or swaping the youks, I did call the local ******* and asked they said the only diff. is the internal things for what that is worth.
Thanks for al the info
Pat is there any way could measure your t-case from front to the center of the u-joint cap too see how it compares too my DLD
Old Jun 1, 2009 | 04:12 PM
patdaly's Avatar
Kinda hard to get an exact OAL, but it is real, real close to 19-5/8" from the flange mounting to the end of the tailhousing. The seal sticks back anoutther 1" or so.
The actual tailhousing is 9-1/2" with another 1" for the seal.
Didn't think it would be good to measure to the center of the Ujoint cap due to it being a slip youke, and each could be slightly different.
doursler
Aug 25, 2013 10:57 AM
Ilikebikes
Jan 4, 2009 07:33 AM
DMAN99
Oct 29, 2007 07:50 PM
2500ho2
Apr 9, 2007 02:50 PM
Bobcat698
17
Jul 18, 2006 07:54 PM
