Tranny??
Old Feb 7, 2008 | 07:25 PM
babyjoe's Avatar
Unhappy Tranny??
....Newbie.!!!
I have a tranny question, I just bought an 01 auto, Have had several dodges over the years but my first diesel, always wanted one but couldn't afford it.
My question or problem is my tranny bucks sometimes at low speed acts like it can decide what gear to go in, possible the torque converter locking and unlocking can anyone HELP ME, Thanks Babyjoe...
Old Feb 7, 2008 | 07:27 PM
Erik@LCD's Avatar
where are you located?
babyjoe's Avatar
Mt.Sterling Illinois...and you..
Old Feb 7, 2008 | 07:41 PM
Erik@LCD's Avatar
Dublin, CA, so not close enough to help you out much personally. I would look around for a shop with a cool reputation and see if you can get an opinion from somebody there. More than likely you are due for a TC/VB at the least. I highly recommend Dave Goerend or Suncoast for all your tranny needs.
Old Feb 7, 2008 | 07:45 PM
babyjoe's Avatar
OIC, Thanks anyway,the guy that owened it before me said he had it replced not long ago, I have read somewhere about adjusting the bands could this be the problem,or should I be asking do these trannies need to be adjusted ever...
Old Feb 7, 2008 | 07:48 PM
Erik@LCD's Avatar
yeah, you can certainly start by adjusting the bands, checking the fluid, making sure there isnt too much metal/clutch sludge in the pan, etc. That will help a bunch
Old Feb 7, 2008 | 07:50 PM
babyjoe's Avatar
I check the fluid last night and it was a 1/2 to3/4 of a quart low, where can I find out the precedure on the adjustments, and is and external adjustment or do you have to go internal...
Old Feb 7, 2008 | 08:07 PM
dozer12216's Avatar
Procedure is in a factory service manaul or a thread on this site.
Old Feb 7, 2008 | 08:11 PM
babyjoe's Avatar
Ok is it externally done or internally like possible by taking the pan off, I know little on the tranny side of things and more on the motor if you know what I mean. thanks dozer..
Old Feb 7, 2008 | 09:26 PM
mr bill's Avatar
Could be an electrical problem. Clean all the grounds. Had the same problem, spent money on a trans and it was sill there. Replaced alternator and problem was gone for a while. Started again just recently so I cleaned the grounds, did the aluminum foil trick (black wire with tan strip if i remember right) on the wire that goes to the pas. battery. also check the 2 connections on that same wire by the passenger battery. Pulled mine apart and cleand them up also. Truck does not cycle back and forth anymore.
Old Feb 7, 2008 | 09:46 PM
babyjoe's Avatar
Thanks Mr Bill I'll try that I have seen the wire you are talking about thanks Babyjoe.
Old Feb 7, 2008 | 10:09 PM
mr bill's Avatar
Just found one of the old posts about this. good luck
"To fix torque converter cycling and transmission shift cycling several options known to work:
1. wrap the alternator output wire with a metallic shielding (tin foil or similar) and follow-up with electrical tape. This is the feed wire from the alternator to the battery (may be black/orange in color)
2. Install a RFI filter on the alternator output wire and/or the APPS circuit wire (APPS sensor to the ECM). Almost any decent RFI filter/choke should work. Search for these terms:
47RE RFI Noise Filter
RF Choke
RF Ferrite Choke
3. Clean all ground-wire connections at the battery terminals, engine block, and firewall.
4. Locate the ground-wire connector for the PCM (behind the passenger-side battery). Cut out the connector and solder the wires together (do not use another butt connector). Seal with heatshrink.
__________________
Old Feb 8, 2008 | 05:44 PM
babyjoe's Avatar
Thumbs up
Mr Bill your the man, Thanks a million.
Old Feb 8, 2008 | 07:25 PM
gooseman495's Avatar
If the stop light switch is out of adjustment flickers on & off, it will cause the convertor to go in & out of lockup. I had 2 different trucks I worked on with this problem. Also a TPS wigging out could cause this.
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
