track bar
track bar
i finally found that the track bar ball joint was the reason i had the DW. so my question is, do i have to replace the whole bar or can i press a new joint in?
It will work perfectly. I just installed mine yesterday and the entire process took about 2 hours taking your time. Id say the hardest part was actually getting the front of the truck on jackstands and removing/reinstalling the trackbar.
If your trac bar was shot you've got other problems in the front end. Ball joints and tie rod ends come to mind. Check the toe and alignment. Worse case: steering box.
Kurt
Kurt
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
