"revving" when starting
Old Apr 17, 2008 | 08:18 PM
shrmpboatcptn's Avatar
my girlfriend has a '02 2500 5-spd with a 24v cummins. her truck revs to 1200 or 1300 rpm's when it starts with no foot on the pedal then idles down to normal. I haven't dealt with 24 valvers as much as the 12-valve ones and was just wondering if this is a sign of something wrong(injection pump dying, apps, sensors, etc.....). Thanks for any help and its greatly appreciated
EDIT: also as far asi know there arent any codes because the check engine light isnt on
Old Apr 17, 2008 | 10:34 PM
come on guys. somebody has to know what it could be
Old Apr 17, 2008 | 10:55 PM
oaborbag's Avatar
Is it when she puts it into gear right away? or just after it starts up in park or neutral it does it?
Old Apr 17, 2008 | 11:49 PM
its a stick shift. but it does it anytime it starts, hot or cold. no foot on the gas pedal. any ideas
Old Apr 18, 2008 | 11:14 AM
paulb's Avatar
Mine did it with a bad map sensor, but mine would set a code some of the time.
Paul
Old Apr 18, 2008 | 01:27 PM
Philabuster's Avatar
There could still be codes even though the CEL is not on.
You can check them without a code reader on the '01 and newer trucks by cycling the key to on-off-on-off-on quickly (without starting the engine!) and read the codes in the odometer window.
PEAKSTRYDE
Oct 11, 2007 04:20 PM
MDMIKE
Dec 14, 2005 09:45 AM
PsRumors
14
Oct 12, 2005 12:01 AM
Korney
13
Mar 31, 2005 11:34 AM
