Too much play in my steering.
Old Feb 11, 2007 | 03:01 PM
milolo963's Avatar
Question Too much play in my steering.
This is my first time using this forum.
I have a 2001 Dodge 3/4 ton 4X4 Diesel truck. I upgraded my tires to a larger All Terrain Tire. Ever since then I noticed that there is more play in my steering. Is this common for larger tires? Are there any adjustments needed? Are there any after market products that could help?
Thanks for you help.
Old Feb 11, 2007 | 04:54 PM
Tommy93w350's Avatar
Where to begin??? The best advice I can tell you is doing a search on the forums. There's some very good detailed advice in the forums.
Basically, check every steering joint and especially the track bar. Check the play in the steering box and tighten it if needed (done this yesterday, huge difference!!).
Old Feb 12, 2007 | 07:40 AM
CRSmith's Avatar
Try doing this TSB before looking into all the various bandaid fixes: http://dodgeram.info/tsb/1997/19-10-97.htm
cincydiesel
May 19, 2009 09:39 AM
klx650a2
Sep 19, 2008 09:28 PM
mr T
24
Jun 15, 2005 01:37 PM
92DIESEL
May 27, 2005 12:20 AM
hellotbone
Aug 5, 2003 11:18 AM
