Toggle switch for toaster relays.
Old Nov 24, 2016 | 11:32 AM
GageMarzigliano's Avatar
I've looked around but can't seem to find anything with answers I'm looking for. What I'm going to is wire a momentary toggle switch to power the toaster relays to switch them on. I did this a few years ago on an old ford I idi I had and it works great.. My question is how many amps should the toggle have going through it to power both the relays on at one time..or should they work independent of each other? I'd also pretty soon like to wire a momentary toggle for the lift pump prime.. To where the computer would run it once the truck was running..but where I could hit a switch for a second or two right before start up to prime it. Sometimes I have issues with the computer kicking it on with ignition so it won't start.. Sorry for the long *** write up. Thanks in advance
Old Nov 24, 2016 | 09:08 PM
patdaly's Avatar
What year truck we dealing with?
You won't need much of a switch, and I would put 2 so you can toggle them independently.
You will be using the switch to bring in the relays that power the grid heaters.
As for your lift pump, I will let someone else answer that, I would think it should be very similar as the PCM controls it, probably just dragging a solenoid to ground.
Old Nov 24, 2016 | 09:13 PM
patdaly's Avatar
Good info on the GH circuits........
Ram Diesel Manifold Heater Problems
Old Nov 25, 2016 | 09:39 AM
My truck is a 99.. Thanks for the info..so for each switch I have to fuse the power to the switch before it hits the relay..so what a ten amp fuse on each switch.. Or less?
pwrtripls1
Jan 27, 2008 07:47 PM
TJE
Oct 29, 2007 12:35 PM
JARHEAD
Dec 18, 2005 03:59 PM
sr148
Dec 6, 2005 09:20 PM
Shovelhead
Jun 18, 2005 08:55 AM
