Throttle Position Sensor or Transmission Problem? `
Old Aug 20, 2009 | 10:55 PM
Symon623's Avatar
Tested it out on the way home from the shop and it works great.. for now... is much better than last week.
Old Aug 21, 2009 | 10:04 AM
clowndodge01's Avatar
if you opt for a new trans you'll just have the same problem just with a more expensive tranny, believe me i called Suncoast and was gonna do the same and this is what they told me was do their fix which is posted on their web page (ground wire from pcm to the radio ground under the dash) I started with battery terminals and it cleared mine right up.
Originally Posted by Symon623
I cleaned battery terminals and problem was gone..... since I also did a fluid/filter service and today I cleaned the ground terminals mentioned above. To me the noise filter and wrap is a bandaid over the "real" issue?????
Mine worked great for as long as I owned it, a year and a half, and 2 weeks ago was havin an issue....... still tryin the cheap/free tricks before I step up to a new trans......
Old Aug 21, 2009 | 01:01 PM
Symon623's Avatar
mine cleared up after battery term cleaning too but I did some of the other tricks too jsut to make sure..... dod not do the suncoast mod though.... yet
Old Sep 7, 2009 | 03:16 PM
footy's Avatar
i'm trying to find the PCM ground connection on the firewall... followed one ground from battery to bolt next to airbox, but the other enters a cluster below the PCM and continues along firewall to other side of truck. am i missing something? do you know where i can find a diagram of these parts etc....
Old Sep 8, 2009 | 08:02 AM
jrs_dodge_diesel's Avatar
I'll try to get a picture of it for you. In the mean time, you are right, it is on the firewall, on the right hand side. The ground wire for it is on the PCM's right hand side as you are looking at it from the front. The ground wire is black in color and was flat shaped with 2 eye terminal on it. And it was roughly 1 foot long.
Old Sep 8, 2009 | 11:07 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Hope this helps.
PCM is on passenger's side of firewall near the air cleaner.
Attached Thumbnails Throttle Position Sensor or Transmission Problem? `-pcm-ground.jpg
Old Sep 14, 2009 | 07:34 PM
GO FIGURE MINES BACK AGAINI AM CURRENTLY DOING ALL THE GROUNDS RIGHT AS I WRITE THIS SO ILL FIND OUT ON THE WAY TO WORK IF IT WORKS. AS OF NOW IVE DONE EVERYTHING EXCEPT FOR THE SUNCOAST TRICK, BUT MY QUESTION IS WHERE THE HECK IS THE DASH GROUND LOCATED? IVE HEARD ITS THE STRONGEST GROUND ON THE TRUCK? THE NEXT STEP... SET FIRE AND CLAIM ON INSURANCE
Old Sep 15, 2009 | 09:16 AM
The strongest ground? Not very likely. It's most likely the cleanest since it is INSIDE the cabin. I don't know where it's located.
The best ground is the negative terminal on the batteries, but it is not very practical to run every single ground wire to them. Which is why they use the vehicle frame to interconnect the grounds, which go to the negative terminals. The best solution to most ground issues to to make sure that all connections (including the wire) are free of corrosion, clean, and fastened tight.
Old Sep 15, 2009 | 10:15 AM
The best ground is the negative terminal on the batteries, but it is not very logical to run every single ground wire to them. Which is why they use the vehicle frame to interconnect the grounds, which go to the negative terminals. The best solution to most ground issues to to make sure that all connections (including the wire) are free of corrosion, clean, and fastened tight.
yea I guess, well I went trough all grounds and am currently sanding down to clean metal vise being painted under all of them so that should work....I hope
Old Sep 15, 2009 | 12:29 PM
That's exactly what I did, and it worked great. On mine though, I didn't like the amount of corrosion I saw on the PCM wire so I replaced that one. Even then I cleaned avery point where the grounds connected.
Good luck, hope it works well on your truck.
Old Sep 15, 2009 | 02:56 PM
WELL wow so far so good seems to be working just fine now. We'll see how long this last, i would think this does the trick points were all pretty nasty corroded
buckshot
Dec 29, 2003 02:24 PM
cavemanscummins
Dec 22, 2003 08:15 PM
KATOOM
Dec 12, 2003 01:20 PM
twhite
Oct 31, 2003 10:50 AM
tishmael
13
Dec 2, 2002 12:39 PM
