throttle position sensor issues
Old Dec 26, 2007 | 09:06 AM
chali84's Avatar
now every now and then when i lay into the throttle the truck takes off but somtimes it will start to bobble up top and evern somtimes down low
it is kinda like it hit a wall and bounces of off it(not like a rev limter)
because other times it will go right through an acceleration run and do fine.
iv talked to some people about this and they all say it is the throttle position sensor
now i looked online and saw they are like 55 buck or 355.
i dont need the bellcrank assembly just the sensor
any thoughts
Old Dec 26, 2007 | 09:47 AM
John Faughn's Avatar
Everybody tell you , that what it might be , testing tells you if it is bad or not .
For motion & sweeping sensors you need a fast testing meter , like a scope , to see glitches .
Old Dec 26, 2007 | 10:11 AM
chali84's Avatar
thats true but i dont have a testing meter and i just figured some of the gooroos on here would know since evry other time iv posted they gave me an answer that worked
what you said is like being the king of the obvious
im not trying to be a jerk but that didnt really help me
Old Dec 26, 2007 | 12:14 PM
mini14's Avatar
check for code 0216 sounds like u got dead peddle
Old Dec 26, 2007 | 09:41 PM
chali84's Avatar
ill check it out thanks man
Old Dec 27, 2007 | 08:30 AM
high bid's Avatar
I experienced the samething. After on the hwy for 3hrs, cruise set and rolling into town, hit the brakes to cancel the cruise and then shortly there after it begins having the dead pedal when accelerating. It acted up for about 30min and nothing since then. I guess if it happens again and continues, I'll have to look into replacement. Thinking it's the TPS/APPS sensor as well. Just ideas.
Old Jan 11, 2008 | 10:48 PM
DavidNeff's Avatar
Can anyone provide a good lead on where to find a TPS/APPS sensor for the best price? I am thinking of just replacing the sensor though it is recommended to replace the entire assembly. Any help is much appreciated, as I really don't want to pay $550 from the local dealer here in Red Bluff, CA.
Old Jan 11, 2008 | 10:58 PM
torquefan's Avatar
I have never seen the sensor available by itself, without the bellcrank. I have never seen it available in the aftermarket either.
To the original poster, I have replaced many APPS sensors, and have never seen one act how you describe. While there is a first for everything, I would check fuel supply first. Seems to me like aeration, starvation, or possibly a failing VP44.
Old Jan 11, 2008 | 11:21 PM
danalex's Avatar
You might want to call below; they may not have it, but will be happy to talk to you about recommendations.
Toll-Free: (800) 755-1715 • Local: (770) 886-2500 • FAX: (770) 886-8811
http://www.genosgarage.com/contactus.asp
Old Jan 12, 2008 | 08:47 AM
DavidNeff's Avatar
thanks. I will give them a call.
Old Jan 15, 2008 | 11:42 AM
Katmandu's Avatar
Arrow
http://www.innerauto.com/store/?N=16...=true&swr=true
Old Jan 15, 2008 | 04:43 PM
AlpineRAM's Avatar
This is a crankshaft position sensor. And this could very well be the culprit for this "hesitation" or "running into the wall" - but usually it should have a check engine light then.
buckshot
Dec 29, 2003 02:24 PM
cavemanscummins
Dec 22, 2003 08:15 PM
KATOOM
Dec 12, 2003 01:20 PM
twhite
Oct 31, 2003 10:50 AM
tishmael
13
Dec 2, 2002 12:39 PM
