Themostat housing
Old Dec 13, 2010 | 03:11 AM
454 no more's Avatar
Themostat housing
Anyone have the torque numbers for the thermostat housing bolts? And is the gasket reusable like the first gen?
Thanks
Old Dec 13, 2010 | 06:38 AM
s-cube's Avatar
From the 2001FSM: Tighten the bolts to 24 N·m (18 ft. lbs.) torque.
Old Dec 13, 2010 | 08:25 AM
Thanks, much appreciated,
Is the gasket reusable?
Old Dec 13, 2010 | 09:20 AM
jrs_dodge_diesel's Avatar
I did. As long as it isn't damaged, you can reuse it.
Old Dec 13, 2010 | 11:53 PM
nickg's Avatar
not so much a gasket as an o-ring
Old Dec 14, 2010 | 11:14 AM
Junk Man's Avatar
O-rings fail. I kept the one that went with the returned non-functional aftermarket tstat as o-ring isn't available by itself. Next, my tstat housing was leaking & I used some rtv as a sealer. Be careful rtv doesn't get where it isn't supposed to. You don't want it floating through your cooling system & plugging it up.
RHC
Mar 4, 2011 08:22 PM
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
1ST GEN.
Nov 6, 2002 09:52 AM
