what next...??need some help
Old Dec 9, 2010 | 07:57 PM
MeanGrn's Avatar
so 2 weeks after a new vp, new lp, and now the starter is burning up fuses and the trucks not starting even after starting fine this morning.
then when i went to start back up after lunch, nothing but multiple blown fuses after 3 tries.
so i bypassed the fuse box and wired up starter direct and it works.
what is causing the amp spike? could starter and contacts be worn just enough to not work and cause things to burn up finally?
any known weak link in this system as most everything on these rigs?
180,000 on the ticker, i will assume the original starter but cant be sure.
i did burn up a few fuses when priming the fuel system a few weeks ago after having some troubles and getting things a little too hot with the starter.
what else am i missing???
i know about the park neutrel swith or whatever that is and i need to get that checked out as well. vehicle is now at wally mart parking lot 50 miles away... arrrrrgggghhhhhh
Old Dec 10, 2010 | 09:24 AM
MeanGrn's Avatar
no ideas...?
Old Dec 10, 2010 | 09:28 AM
high bid's Avatar
you probably have something shorting out the wire(s) and thus blowing fuses. If your batts are good, connections are clean and tight your starter should spin w/no problem. If not, then it's the starter contacts. You can easily repair/replace them w/heavy duty contacts.
Old Dec 10, 2010 | 10:10 AM
Junk Man's Avatar
Blown fuse = resistance or direct short to ground. The 01 wiring diagram is at pdftown. Perhaps starting circuit is the same. Have you checked the starter & solenoid itself? I hate working in the cold.
Old Dec 10, 2010 | 11:57 AM
MeanGrn's Avatar
yep, 30 degrees at 7800ft in colorado, snowing hard here today and i get to go play in wally mart parking lot 50 miles away again to see if i can get this thing started and come home before dark, at least i will have proper clothes and tools with me today, had go to town shopping clothes on yesterday and no tools what so ever that will never happen again, i will have all tools and all the extra parts i own with me at all times and treat it like i am on a full time expedition since i seem to be at the stage to replace everything hooked to this truck and engine
Old Dec 10, 2010 | 12:04 PM
stlhauler's Avatar
Hey MeanGrn the same thing happened to me. Go to start the truck and it would blow a fuse, not all the time but got worse & worse, turned out the contacts in the starter contacts were shot. search E-bay and found heavier replacements fairly cheap. problem solved! Good luck!!
Old Dec 13, 2010 | 07:36 PM
MeanGrn's Avatar
what would u do...?
yea, same thing here, i have gone to fosters and loked at their rebuild and new starter with heavy contacts, what would any of you do at this point?, i dont have a good auto electric place where i live so i think i have to buy this new rig(almost $400), i can get a remaned from napa for less that $200 but i can assume it is not a denso unit... which i will also assume we want and not some china, mexico junk...
Old Dec 14, 2010 | 07:11 AM
stlhauler's Avatar
Meangrn I would pull out the starter and check the contacts. It's really simple to check, I got my oversize contacts from LarryB's for around $20, only took a couple day's to get thru regular mail. The starters from the stores are said to be cheap and not hold up well.
Old Dec 14, 2010 | 11:20 AM
MeanGrn's Avatar
why cant anyone tell me at 180k how much life might be in this thing? what is the average life span?
Old Dec 14, 2010 | 12:02 PM
rickf's Avatar
You said you heated it up trying to prime the system. You should only crant for 10 seconds with 30 off. You could well have crispied the starter.
Rick
Old Dec 14, 2010 | 05:09 PM
stlhauler's Avatar
Mine has 131k and after the new contacts works great. When it doesn't blow a fuse, how does it sound? strong? turn over the motor with no problem?
Old Dec 14, 2010 | 08:12 PM
MeanGrn's Avatar
yea it just cranked back up after i bypassed the fuse but i'm not gonna take any chances just gonna replace it, our local napa owner pm'd me on another forum and he has a new denso for $200, gonna do that asap and do the new heavy contacts before i install it
kevellis32
Nov 11, 2007 09:25 AM
cyric
Aug 26, 2007 08:41 PM
JD730
Nov 27, 2006 05:54 AM
MDMIKE
15
Sep 10, 2004 12:11 PM
