stupid oil leak
Originally Posted by rjohnson
The kit from Cummins has the same seal in it that caused the problem in the first place!!
I think it's more than $10.00... but not sure.
The kit from Fixinrams is $59.00, comes with instructions on a DVD and will never have a problem again... period.
RJ
RJ
RJ
RJ
. I used a couple different sockets which matched the size of a couple of the seals in place of the "tools" that the Fixinrams kit has.Gafirefighter...pm me if you need some more info/advice.....I think I could do that fix over the phone to ya with out pulling the p.s. pump....I left mine attached to the engine....didn't want to mess with the lines & fluid.
I'm a little confused. Does the cummins kit come with a replacment gasket where the vacuum pump attaches to the block. The new ones from Cummins are metal with a rubber lip (factory is paper) and cost $6.00 by themselves. Add in O-rings and the seal itself... $8.00 bucks does not sound right?
Did mine without removing PS pump also.
RJ
RJ
RJ
RJ
cummins Part# 4098742
RJ
RJ
I couldn't imagine scrapping the whole pump assembly ($$$) like some have done for such a simple fix.
