strange LP performance
Old Jan 12, 2004 | 05:51 PM
Tartarus's Avatar
Truck has 24K miles, and I'm on my second lift pump, installed last summer. This one's a bit weird -- I'm wondering if they've changed the design, or ?
idle -- 16 psi
-anything- above idle -- 12 psi
WOT -- 12 psi
WOT uphill, pulling a load, 85*F ambient, 1250*F EGT -- 12 psi
Rock steady, never changes, pulling loads, cruising, lugging, getting on the pedal. Not the gauge, checked it with another.
Got -6AN fittings, lines from the LP to the VP, don't think that means anything, though.
Old Jan 12, 2004 | 06:00 PM
DPG's Avatar
DPG
Those are unusual readings, Tartarus. If they are accurate, you're pretty lucky! I haven't heard or read of any major changes in LP design. Is the pump you put in a Cummins pump?
DeWain
Old Jan 12, 2004 | 08:11 PM
Tartarus's Avatar
It's a warranty replacement from a DC dealer. Looks identical to the OE. Can't figure out how it could respond so quickly to throttle changes (inside the limits of the gauges); thought it might have a new internal regulator or check ball design.
Sean S
Jul 7, 2007 11:23 PM
scottrod
Nov 14, 2002 11:25 AM
AFMSgt
Nov 13, 2002 02:29 PM
CRobey4393
Oct 30, 2002 08:01 PM
heavyg
Oct 25, 2002 05:06 AM
