Stock Turbo Longevity
Old Nov 16, 2007 | 11:58 AM
Grider Pirate's Avatar
I'm relatively new to the CTD world, but haven't read ANY threads regarding failure of the stock turbocharger. Do they ever fail?? It seems like anything that spins that fast for that many miles ought to fry sometime.
Semi-related: If the stock turbo really does last virtually forever, and people are putting bigger-better-faster tubos in, are their a bunch of perfectly good stock turbos out there? If so, I'd like to buy one really cheap to build a small, completely impractical turbine jet engine from.
Old Nov 16, 2007 | 04:18 PM
wurkenman's Avatar
I think they go a long time without any mods and regular oil changes.
Old Nov 16, 2007 | 04:33 PM
graphitecumnz's Avatar
Stock turbo's can last a long time if they're not "overspun" or cooked by towing really hot.
Old Nov 16, 2007 | 06:43 PM
65pacecar's Avatar
stupid question here maybe, but how do you change the turbo oil? Also, I have the stock air filter and box and I am probably ready for a filter change, should I stay stock or does any of the aftermarket stuff help with performance.
Old Nov 16, 2007 | 06:56 PM
CamperAndy's Avatar
He did not mean turbo oil change, as the turbo uses the engine oil system. He was referring to guys that run 20,000 plus without changing oil in the engine.
Old Nov 16, 2007 | 07:57 PM
65pacecar's Avatar
Thanks, I thought it was in the normal oil route, but the post made me second guess myself.
Old Nov 16, 2007 | 10:29 PM
Kennys's Avatar
Have 400K on mine with no problems. Always careful to let it cool down before turning the engine off. Have a friend that ran a school bus shop. When they started getting in diesels he explained about letting them cool down a bit. They had several failures. He called them in again and told them that any more failures would have to be at the expense of the driver. Never had another failure.
Old Nov 17, 2007 | 06:31 PM
dspencer's Avatar
OOps! I haven't changed oil in 78 thousand miles. Add a little but no change.
Old Nov 17, 2007 | 07:11 PM
wurkenman's Avatar
Dont change it now, probably all that is holding it together
Old Nov 17, 2007 | 10:54 PM
dspencer's Avatar
I'm Amsoiled.
Blessed
30
Jun 5, 2016 12:13 PM
jetski428
Nov 25, 2008 09:09 PM
supercharger
Mar 22, 2004 09:34 AM
sdgunslinger
Apr 5, 2003 07:42 PM
jlells01
Feb 1, 2003 03:57 AM
