Stock 47RE Transmission
Old Nov 27, 2009 | 03:22 PM
kX500's Avatar
I have a stock 47RE, I will start the truck up after the truck has sat for a few days to a week, il put it in gear and the transmission will not engage for a few seconds then all of a sudden it will slowly start to engage and all is well. I dont know much about these transmissions, does anyone know what causes this? Is something I should wory about?
Old Nov 27, 2009 | 03:59 PM
tjs88yj's Avatar
Fluid draining out of the torque converter?
Old Nov 27, 2009 | 04:43 PM
bling's Avatar
sounds like fluid drain back a common problem with our transmissions
sonnax make a kit that fixes all the little issues related the 2nd gen auto trans
that will take care of the little issue plagueing the trans
Old Nov 27, 2009 | 04:55 PM
patdaly's Avatar
As others have said, TQ drainback. I just put it in neutral for a few seconds and it then engages correctly.
Old Nov 27, 2009 | 08:31 PM
67HotRod's Avatar
TQ drain back. I pulled out all the check ***** when the trans was rebuilt, trans runs a little cooler.
Old Nov 27, 2009 | 11:53 PM
kX500's Avatar
Great, Thanks guys. It sounds like its fairly common, and not too big of a deal. Il be sure to put it in Neutral for a few moments before going into gear. Thanks again.
Old Nov 28, 2009 | 07:11 AM
hamilton71801's Avatar
I have a built HTS and mine was set up that way. No check ***** for me either. I've heard that if one gets stuck, it can burn up the tranny fast!!!
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
cmckinney
Aug 13, 2003 10:14 AM
BuckBoardDriver
Jul 3, 2003 07:30 AM
firefighter2000
Mar 7, 2003 07:57 PM
