Starting Troubles 2000 Ram
Old Oct 22, 2008 | 05:31 AM
premo 1's Avatar
From: St. Louis, Mo Home of Busch& Budwiser Beer and Kurt Warner---opps I mean the RAMS
I have a 2000 dodge ram and it is taking longer to start than usual. It almost seems that it is flooded like a gas engine. If I press up and down on the go pedal it will start. It used to start on a few turns of the starter.
Does anyone have any ideas?
Thanks
Old Oct 22, 2008 | 11:36 PM
NoSeeUm's Avatar
Any codes?
Jim
Old Oct 23, 2008 | 07:08 AM
mahdey's Avatar
does it do it when the engine is cold too? Mine did it when the engine was hot, took about 5 seconds to get her to fire up. Ended up replacing the vp 44 and now i bump the starter and she comes to life.
Old Oct 23, 2008 | 11:25 AM
MikeR's Avatar
You could do the key-on trick to see if any codes flash in the odometer window.
Don't start the truck, but with a steady rhythm, cycle the ignition key: on, off, on, off, on
Then if there's any codes stored, they will flash in the odometer window.
Old Oct 23, 2008 | 12:34 PM
johnh's Avatar
not all, maybe some.... even '01 doesn't get all the codes that way.
that's why i bought a cheap scanner from checker auto
Jdiesel
Nov 29, 2011 02:32 PM
b12
Feb 24, 2008 11:26 PM
Cloud 9
Oct 7, 2007 05:01 AM
ReedRosa
Dec 8, 2004 11:26 PM
thatguy
Nov 19, 2004 10:07 AM
