problem starting 2000 7.3 powerstroke
Old Feb 21, 2008 | 07:11 PM
b12's Avatar
b12
pick-up started hard and it was 30 degrees, had to run the glow plugs three times and it had a lot of white smoke when it did start
Old Feb 21, 2008 | 07:20 PM
reecegr's Avatar
Buy a cummins,or find one to pull you where you need to go.
Old Feb 21, 2008 | 07:26 PM
b12's Avatar
b12
I know it's my brothers pick-up
Old Feb 21, 2008 | 07:30 PM
cnhdoc's Avatar
I'm thinkin you need to trouble shoot an injector problem.
Old Feb 21, 2008 | 07:47 PM
b12's Avatar
b12
maybe a weak or slightly plugged injector?
Old Feb 21, 2008 | 07:51 PM
scottsjeeprolet's Avatar
Just use lots and lots of Either!!!
No just kidding, friend of mines friend did that on his powerjoke and blew the intake off.
You could always tow it to the local dealership and trade it for a cummins.
Old Feb 21, 2008 | 08:02 PM
crabbelle's Avatar
how long has it been since it was started last, my ford sat for about 2 weeks with about being moved and it was a little mad when i tried starting it, but i cranked for about 10 secs then fired right up, white smoke too. what has been done to it? i took out my intake heater. but kept the ebpv
Old Feb 21, 2008 | 08:37 PM
b12's Avatar
b12
it was just started a day ago, it has a superchips programmer and K&N filter
What is the ebpv?
Old Feb 21, 2008 | 08:48 PM
OldDodgeOwner's Avatar
I'd say check the glowplugs first, had that same problem with a 99 Powerstroke
Old Feb 21, 2008 | 08:56 PM
b12's Avatar
b12
olddodgeowner
what is the easiest way to check the glow plugs, and what should i get for a reading?
Old Feb 21, 2008 | 09:03 PM
crabbelle's Avatar
engine back pressure valve, puts load on the engine to warm up faster. its what makes the kissing noise when its cold. but check the glow pugs or relays or go to dieselstop.com, all ford website. you will deff get answer there.
Old Feb 21, 2008 | 09:07 PM
I don't know for sure on checkin the glowplugs, the truck had 200k on it, so we just replaced em and it solved the hard start problem
Old Feb 21, 2008 | 09:17 PM
strokerace's Avatar
Check your glow plug relay, they are a common problem on those trucks, I've had 2 of them, and replaced relays twice on one and three times on the other. If you have a multimeter you can check the wire (I believe its brown) that comes into the left side from the battery and you should have 12 volts there, then have a buddy turn the key on (dont crank) and check the other side (black or red wire I think), it should read 12 volts for 30-45 seconds, mine were both in the 35 sec range, after that time there shouldnt be anything there until you cycle it again. One common misconception is that the wait to start light is connected to the glow plugs, this isnt the case, the light goes off after a few seonds but the plugs are still on, so cycling your plugs 3 times in 30 seconds isnt any different than just waiting. If thats not your problem it could be your plugs, my factory plugs lasted 110,000 and I did em the second time around at 165,000. They arent to bad to replace you can probably do all eight in 6 hrs or so your first time. The ebpv is the exhaust back pressure valve, I dont believe thats your problem though, the symptoms dont add up and I never had any troubles with it in either one of mine. The white smoke is your plugs not working or your relay is out, mine used to crank for ever (wore out 2 starters) and when it fired (if it did) it just poured out so much smoke (even at 40 degrees) that if the wind was right you couldnt see the truck anymore and the parking lot would be a cloud of smoke, made for some interesting conversations with other people explaining why my truck did that. I replaced the plugs and did the relay at the same time and the smoke went away. Powerstrokes are just notoriously cold natured, thats one reason why I went to cummins. Thats a place to start anyway, if you have anymore questions just shoot me a pm and I'll try to help you if I can. You can also try powerstroke.org theres lots of powerjoke info on there. Sorry its so long but I hope I helped you some. Good Luck
Old Feb 24, 2008 | 11:26 PM
b12's Avatar
b12
is there more than 1 glow plug relay?
thanks for all the feedback guys
fourthandgoal
88
Dec 27, 2011 05:39 AM
Jdiesel
Nov 29, 2011 02:32 PM
RED99CTD
Apr 20, 2011 08:08 AM
premo 1
Oct 23, 2008 12:34 PM
abc4yew
Mar 15, 2007 11:55 PM
