Speedometer Quit
Old Apr 25, 2007 | 10:52 PM
jlebrun's Avatar
Speedometer Quit
Well, last week i was going down the highway and my cruise shut off. i looked down and the speedometer was bouncing around 45-50 and i was going roughly 75. Then, the other day it quit. The brake and abs lights are on and i have no speedometer and the odometer doesnt work either. I crawled underneath and checked the power and ground to the speed sensor and both were good. I then put in a new speed sensor and still nothing. Any other ideas on what i should try? thanks
Old Apr 26, 2007 | 10:29 AM
tx_2500's Avatar
when mine did that i changed out the speed sensor in the rear and that solved my problem instantly. which one did you change? the output shaft sensor on the trans or the one in the rear diff?
Old Apr 26, 2007 | 11:02 AM
jlebrun's Avatar
i changed the one on the rear axle
Old Apr 26, 2007 | 10:55 PM
tx_2500's Avatar
hmm, then i dunno man. maybe check your wiring to make sure its not grounding out or worn through
Old Apr 27, 2007 | 02:44 AM
BCSCUMMINS's Avatar
Check your ABS fuse on the side of your dash. I used to pull that fuse to shut off the speedometer when I was still under warranty to keep miles off the truck. I hade all the same lights on and the cruise wouldn’t work.
Old May 14, 2007 | 09:21 PM
jlebrun's Avatar
well, now im pretty sure its a wiring problem. the other day it was raining and everytime i would hit a water puddle, the speedometer started working again for a few minutes.
Old May 16, 2007 | 12:40 PM
RAMpage's Avatar
does the wiring for the speed sensor go straight to the dash or does it go to the comp on the side of the block first and then to the dash?
Old May 16, 2007 | 05:45 PM
phox_mulder's Avatar
Automatics need both sensors for the speedo to work, the one on the rear pumpkin, and the one in the transmission.
You could also have a loose or damp connection at the ABS computer.
phox
Old May 19, 2007 | 06:17 PM
2RamsNoCash's Avatar
when mine quit I replaced the one on tranny first(as I have had to on alot of GMs) that didnt fix so I did the one on rearend it shot a code and worked after I cleared it.the lights went out immediately but a code came up and no speedo,after clearing been fine for over 40k.
Old Jul 18, 2007 | 02:13 PM
Geico266's Avatar
Wow, DTR strickes again! I seached this thread up after my speedo quit. It was my rear differential speed sensor. It cracked and allowed water & dirt it and the copper wire broke.
Thanks DTR!
foghorn
May 2, 2015 08:16 PM
Darrin F.
Jun 14, 2012 08:10 AM
sabercat
Feb 18, 2009 02:03 PM
raggmann
Oct 29, 2008 01:13 PM
Rampuller
Mar 15, 2003 05:35 PM
