Spacer under right wheel
Old Jun 23, 2006 | 01:43 PM
PChouinard's Avatar
What's the idea with the spacer between my rotor and wheel on my front right? Do all 4x4s have this? It looks original but I bought the truck used so I really don't know. It is stamped with RH ONLY on it. Any info would be great..
Old Jun 23, 2006 | 01:49 PM
nitrousn's Avatar
My 2002 2500 has no such spacers. How thick is it?
Old Jun 23, 2006 | 01:51 PM
PChouinard's Avatar
It's about 3/8 of an inch thick and as big around as the contact surface between the wheel and rotor.
Old Jun 23, 2006 | 01:54 PM
Shovelhead's Avatar
Administrator / Scooter Bum
It was the early "Fix" for the drift to one side when running straight problem in some of the earlier trucks.
Old Jun 23, 2006 | 01:56 PM
PChouinard's Avatar
I guess I'll leave it there then. Thanx..
Old Jun 23, 2006 | 02:22 PM
phox_mulder's Avatar
Seems to be common on 1999 trucks,
why that year was "special", who knows.
Make sure it doesn't stick to the rim when rotating your tires.
phox
Old Jun 23, 2006 | 02:50 PM
RustyJC's Avatar
Actually, it was used to "cure" brake pull - if the truck pulled left under braking, a spacer went under the right front wheel. HERE is TSB 05-03-97 / 05-04-99 for your reference.
Rusty
Old Jun 23, 2006 | 09:22 PM
PChouinard's Avatar
Man you guys are full of good gouge.. Thanx again...
big stinky
Nov 1, 2014 03:22 PM
gkainz
Nov 17, 2005 07:31 AM
Buz
18
Jul 16, 2004 09:41 AM
I PASS GAS
Feb 18, 2004 08:52 AM
Stamey
Feb 17, 2004 07:45 PM
