Some Pump? Help
Some Pump? Help
Ok I have a 01 3500 and I have this pump that wont stop running, and I have been just unplugging it when the truck isn’t running. Its to the right of were you hold your brake fluid if your looking at the grill. And it has 2 clusters of wires were it plugs into it and I just need to know what it is and y isn’t it stopping. Some of my friends said it is what keeps pressure to my brake and clutch but I don’t know. Please HELP!
Spencer
Spencer
That is indeed your abs pump. and you need to find out what it causing it to run constantly. Look in the PDC, just ahead of that unit, and you should see a relay for the ABS. Pull that relay, if the pump stops running, swap the relay with another similar one. If the pump stays off, the relay has stuck in the closed position, and must be replaced.
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
