Slow speed vibration
Truck only vibrates at low speeds between 5-10 mph -- accelerating or coming to a stop. So I had the shop looked at it and they found the driveshaft is moving up and down. They told me that it needs the rear drive shafts ujoints, center carrier bearing and the driveshaft balanced. All for about $520.
Does this sound right to you guys? I figured I can do change the ujoints (cheap enough) myself and maybe the center carrier bearing. I've never done any of these jobs before but I'm willing to learn how to do it.
Does the shaft really needs to be balanced after all these parts are replaced? What kind of shop does shaft balancing? thanks.
Possible but....?
If you hace a FSM (field service manual) you could figure how to do most, if not all, of it yourself.
Have you gone underneath to see if u-joints and carrier look loose?
Any play at pinion.... rear differential entry point?
Checked for drive shaft damage (dents. dings, etc) anything that would cause imbalance?
Bad U-joints and an imbalanced shaft are two separate and different things.
Could all be bad but I would not think so.
Total Mileage?
RJ
Total Mileage?
RJ
That mileage could be about right for needing U-joints and a carrier bearing.
I would change or have those changed, and then see if still a vibration.... indicating drive shaft has a problem (assuming no visual damage).
RJ
RJ
Took the driveshaft off the truck and had the driveline shop nearby replaced all three u-joints, the carrier bearing and balanced the driveshaft for $343 (parts and labor, bearing was $150
i was told it's a "special" one, is that about right or did I get ripped off?). Oh well too late now but the truck runs awesome. Truck is so much quieter -- there was this humming noise between 50-60mph that is now completely gone. Truck even shifts better now. It used to be a little "jerky" on downshifts. Not certain if thats related to the driveshaft issue.
Thanks for the all the advice.
i was told it's a "special" one, is that about right or did I get ripped off?). Oh well too late now but the truck runs awesome. Truck is so much quieter -- there was this humming noise between 50-60mph that is now completely gone. Truck even shifts better now. It used to be a little "jerky" on downshifts. Not certain if thats related to the driveshaft issue.Thanks for the all the advice.
Yes, that does seem excessive since there was nothing "special" about your driveshaft, but hey.....at least your truck is fixed and runs great. Balancing is never a bad idea either and its not even to terribly uncommon for an OEM driveshaft to leave the factory and be a little out of balance. I wouldn't worry about it to much. You could have shopped around and saved a $100-$200 but then who knows how well they would have done the job.
I actually shopped around and the first shop wanted $523, second was $327 just to do the u-joints so this was the best deal could find without spending a lot time shopping around. I shop that did the work has a really good reputation and specializes in trucks and other heavy equipment repairs.
lookin4cowgirls
13
Jul 23, 2018 02:26 AM
Pipes
Jun 15, 2006 10:33 PM
Ripper406
Nov 27, 2004 07:58 PM
Scotty
88
Jan 1, 2004 08:00 PM
