Do Toyo Proxes squish & squeek at slow speed?
Old Oct 17, 2007 | 01:16 PM
04ctd's Avatar
i got some tires & rims cheap.
305-40-22, and they only have a few thousand miles on them.
been spun quite a bit (big HP show truck) but not drove much.
when you roll down the windows and back up the driveway, or coast around a parking lot, they make a "squeege" sound.
the rims are 3 peice KMC Backseats (search for thread Mega on 22).
i have them torqued to 100ft lbs with a torque wrench.
50psi max (per rim & tire labels)
Old Oct 17, 2007 | 02:27 PM
haloman's Avatar
Visibly squished? Maybe too much tire shine?
Old Oct 17, 2007 | 02:30 PM
04ctd's Avatar
nah, just noise.
there's barely enough sidewall to put tire foam on.
no big deal, just kinda odd...
Old Oct 17, 2007 | 02:58 PM
rip 112's Avatar
I've had Toyo Proxes on a few of my vehicles. I don't know of any squeaking unless I was on a certain type of concrete like the smooth shiny concrete some driveways are made out of.
Old Oct 17, 2007 | 05:06 PM
04ctd's Avatar
http://marktg.toyotires.com/file/35.pdf
these rascals are 12.3 inches wide. not sure if that makes any difference.
doesn't seem to be affecting anything.
just thought to ask...
http://s27.photobucket.com/albums/c1.../KMC-backseat/
Old Oct 18, 2007 | 02:15 AM
AlpineRAM's Avatar
With those low sidewall you may want to adjust toe-in to almost 0 degrees. The stock higher sidewall will flex a lot more and the tread will roll straight even with the toe-in, but the low sidewall will force the tread to slip a little to accomodate the toe-in.
AlpineRAM
04 Diesel
35
Sep 8, 2009 08:43 PM
53 willys
40
Jun 1, 2008 08:25 PM
Txwelder
Jun 3, 2005 07:34 PM
Ken W
Jul 23, 2004 05:24 PM
Jim Shulmister
Feb 19, 2003 01:37 PM
