Small antifreeze leak
While under my truck fixing the leaky diff cover I caused when I swapped my fuilds, I noticed a small amount of anitfreeze has dripped down around the front oil pan bolts. It appears to be coming from over by the serp. belt idler.
? any ideas?
? any ideas?
I knew someone was going to ask that, I ran out just after I posted........
I can't see a 53 anywhere. The only thing I really see is a big "M", and an "ABC".
It has the belt and idler pretty well wet, but the rad. and tank are topped off? Muat have just started, where ever it is.................?
Anyone ever heard of a pinhole in the water inlet neck (thingy) where the top hose connects? The underside of it is green, It would be tough for it to get up that high if it was leaking any lower than that. Unl;ess it is being sprayed up there from the belt?
(if you know what I mean....?)
Originally Posted by OUTDOORSMAN
btw, the fan blew anti freeze all over. i wasnt sure where it was coming from till i pulled the belt.
I'll pop the belt of and check like you said,
Thanks for the tip.
Yep, the water pump is toast. Should be no play, and it should not feel rough or make noise when turned. A new one will not "spin" because the seal has too much drag, but it will be smooth and tight.
You will spend more time draining and refilling the system than swapping pumps.
And yes, that is a Cummins water pump. I got mine for about $15 less than that at a heavy truck parts house, so you should try that if you have one local.
Thanks Dave. Looks like Auto Zone is going to spank me $59.00 for a new one with lifetime warranty. Just in time for me to sell or trade it, sweet! Might as well throw a new serpentine belt on there too, mine is all crackly on the inside
Don't have much of a choice, I am working on one of my aunts rentals up in West Chester this week, can't be broke down..............
Drove a new 6 speed, silver dually SLT yesterday, as soon as I get a decent buyer for my truck and we hash out the last few hundred or so on the new one she'll be mine!!!
Okay, you guys aren't done yet.
Whats the best way to drain my system? Is there a petcock somewhere or an I going to take a bath popping the lower hose?
