Rear band adjustment
Old Aug 14, 2006 | 04:25 PM
Blackhawk's Avatar
How important is the torque on the rear adjustment? I got a rinky dink torque wrench from Harbor Frieght. As you know 70 in/# is not much torque. Not sure the wrench knows as much as I do, anyway I turned the screw in quite a bit and it still did not register the proper torque. I was afraid I was going to run out of thread. So I backed it off and tightened it down. It is tighter than it was but not to specs. I have 115k and it has never been adjusted. There was quite a bit of metal on the magnet on my fluid plug. Did I do wrong???
Old Aug 14, 2006 | 04:29 PM
Mcmopar's Avatar
Buy yourself a good wrench and do it properly, you can burn that band up if it is not right!!!! There won't be much sticking out (threads) at 72" lbs.
Old Aug 14, 2006 | 04:51 PM
Blackhawk's Avatar
I understand doing it right. I do not have it as tight as it should be but it is not a loose as it was. Did I do it any harm?
Old Aug 15, 2006 | 08:30 AM
Mcmopar's Avatar
If you are close to the spec, then probably not. There is some leway--but if you loosen it say 4 turns as opposed to two you could fr the band.
Old Aug 15, 2006 | 10:19 AM
whiteVLX's Avatar
Just so there's no confusion by a newbie in the future, you torque to 72 in/lbs and back off the rear band 3 turns. Front torque to 72 in/lbs and back off 1 7/8 turns.
betsycam
Sep 26, 2004 03:44 AM
miketriton
Aug 20, 2004 01:14 PM
Outlaw02
Jul 8, 2004 10:16 PM
vtailflyer
Feb 1, 2004 06:43 PM
Dodgezilla
May 6, 2003 06:50 AM
