Raptor Install
Raptor Install
Getting ready to install a Raptor 150 and looking at the instructions one diagram shows the fuel lines "looped", it looks like the inlet loops around the top of the pump from the tank, and the outlet loops back around the top again towards the fuel filter (Appears pump is mounted with inlet facing front of truck, outlet towards tank). Is this correct, or am I reading it wrong? The only reason I can see is to maybe keep air out of the lines or something?!?! Any help is appreciated.
If you mount the pump on the inside of the frame rail, then the input is toward the front of the vehicle and the outlet is toward the rear. This is why they loop. I put a cutoff valve on mine, in case I ever need to service it in the future.
I have a short bed, 4x4 and I put mine as far forward on the inside frame as I could. Not much room in front of the fuel tank, but I did get it in. Probably not an issue with a long bed. I used the supplied brackets.
White97GTVert
13
Apr 21, 2011 08:51 PM
Bigsmoke3500
May 28, 2008 08:00 AM
goose2w1
Feb 29, 2008 08:45 AM
84mphcdt
16
Dec 19, 2007 11:31 AM
