Question
Old Apr 15, 2008 | 08:28 PM
Bodean's Avatar
Question
I posted this in the wrong place the first time so here it is in theright place. I have a 99 2wd auto CTD with 188k on the clock. Yestrerday I was getting off the interstate and as I approached the stop sign the truck went dead. This has never happened before. It started right back up and ran fine. Today I noticed that the truck is shifting late (not always) sometimes. Any ideas?
Thanks!
Old Apr 15, 2008 | 08:51 PM
rich's Avatar
maybee va lift pump issue not sure about the shifting tho
Old Apr 15, 2008 | 08:55 PM
Bodean's Avatar
I have a guage on the pre filtration side of the F/F housing and I have about 15psi at idle when hot. ???
Old Apr 15, 2008 | 09:21 PM
wurkenman's Avatar
You might want to consider putting your pressure sensor right at the injection pump.
Old Apr 17, 2008 | 07:45 PM
Bodean's Avatar
Ok, now the truck won't shift out of second gear. I went to pick my daughter up after driving fine and when I started it back up it wouldn't shift. Playing with the shifter made no difference. Could it be the throttle position sensor?
Thanks!
Old Apr 19, 2008 | 08:42 AM
Bodean's Avatar
Talked to the good folks at dieseltrans.com and they told me to check the Gov. solenoid and the trans. output sensor. Said it sounds like an electrical problem.
Old Apr 19, 2008 | 02:08 PM
Bodean's Avatar
Well... it's fixed! $17.00 speed sensor was the culprit. Better than the alternative!
Later,
Old Apr 19, 2008 | 05:48 PM
dj_souvlaki's Avatar
Later,
good to hear
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
