Problem with my trans
Old Apr 11, 2007 | 11:24 PM
DAN POUCHER's Avatar
I have a 2000 dodge diesel short bed 4wd automatic trans, when driving down the road between 35 and 50 mph the transmition shifts up and down every 3 to 4 seconds i have to either apply more gas or let out to get it to stop doing it, i have a 113k on the truck and have changed the fluid and filter 4 times since new the last time the fluid was clean and bright not burnt at all. does anyone have any suggestions on what could be causing this ?
thanks Dan
Old Apr 11, 2007 | 11:28 PM
AllanP's Avatar
Check your ground wires. Also if you do a search you can probably find a lot of info on this problem.
I had the same problem and had to buy a Happi box. It has worked great for years and the problem has never returned. www.happibox.com
Old Apr 12, 2007 | 09:50 PM
badme's Avatar
AllanP is right, check the grounds. Mine did that and I added a ground wire from the battery to the apps. Works like a charm now.
Old Apr 13, 2007 | 03:53 PM
Hardcase's Avatar
Hey badme can you give me a little more on adding a ground wire from the battery to the apps? What size wire did you use, etc?
Old Apr 13, 2007 | 04:44 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Try cleaning the battery terminals and cables to ensure a good connection as a preliminary step.
Old Apr 13, 2007 | 08:04 PM
badme's Avatar
I just went to my wire rack and picked a roll of black that looked good at that moment. The guage is not that important. 10,12,14 what ever you got will work.
Then remove one of the bolts that hold the apps on. They are the 13mm ones.
Run the ground wire from the bolt to the battery ground terminal. The idea is to remove line noise, you can buy a noise filter or I have seen threads to reroute the apps wires but this is fast, cheap, and easy.
Old Apr 14, 2007 | 09:46 AM
Hardcase's Avatar
Thanks I'll try it. I already have cleaned the battery terminals and cables.
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
