Power Steering fluid or Dextron?
Old Dec 1, 2007 | 01:01 PM
nickg's Avatar
PS fluid is recommended, anyone ever see any ill effects of running Dextron/Amsoil ATF instead?
In the Canadian Military we ran dextron in the 1976 Chev 5/4 ton trucks(basically a SBC 350ci and the truck was really only a 3/4 ton) for 20yrs, they basically had the same hydroboost system, I dont remember too many issues with that, and definately none related to the fluid.
any comments are welcomed.
Old Dec 1, 2007 | 09:04 PM
fschiola's Avatar
I've never seen anyone that ran ATF in the steering box so I can't tell you about any ill effects. If it was me I would stick with the recommended fluid type.
Old Dec 1, 2007 | 11:05 PM
dssimecek's Avatar
I would stay with P/S fluid. Read somwhere that ATF is hard on the seals in the newer P/S units. I suck out the dirty p/s fluid with a turkey baster, and installed valvolene synthetic. Made it smoother and quited it down.
Old Dec 2, 2007 | 12:08 AM
Kennys's Avatar
Have about 400K on mine with no problems using Valvoline synthetic. Have not replaced any hoses or seals, yet. Do change the fluid occasionally.
Old Jan 10, 2008 | 08:58 PM
fbx22's Avatar
I like the turkey baster idea. Never thought of that
Old Jan 10, 2008 | 09:34 PM
danalex's Avatar
Turkey baster--can you get all the fluid out?
01 2500 xtd cab, 65k, K&N air, stock, autom. -d
Old Jan 16, 2009 | 09:54 PM
thatguy's Avatar
I was browsing thru a lot of PS fluid posts this evening I have seen this mentioned several times.. its basically like draining the transmission fluid and then adding back what you drained...
You suck as much of the fluid out as possible and then refill (I think you have to make sure you dont damage some screen down there though).. run it for a while and then suck/refill again.. lather/rinse/repeat several times.. You slowly get a mixture of new fluid in there..
Brian
Last edited by thatguy; Jan 17, 2009 at 06:34 AM. Reason: later was suppose to be lather
Old Jan 16, 2009 | 11:04 PM
mini14's Avatar
the valvoline synthetic is the ticket...it stops the cold weather growl also.
Old Jan 16, 2009 | 11:34 PM
Fishin2Deep4U's Avatar
I am using the Valvoline as well. Sure quieted the pump down.
Dave
Old Jan 17, 2009 | 07:47 AM
Valv's Avatar
On 3rd gen trucks Dodge prescribes ATF+4. It's in the owners manual and service manual too.
I don't see any difference int the system between 2nd and 3rd gen, I would go with ATF+4 which is also a synthetic fluid.
I like when it gets simple, everything with ATF+4, transmission, transfer case, PS pump. Only front and rearend gears have different fluids. Saves from having 10 different kinds of bottles in the garage...... or in the toolbox
Old Jan 17, 2009 | 10:05 PM
Barney's Avatar
Should probably adhere to the recommended fluids.
TSB 19-005-03
Power Steering Fluid Usage
http://dodgeram.info/tsb/2003/19-005-03.htm
choppers555
13
Sep 27, 2009 08:04 PM
BobQ
Apr 17, 2006 10:24 PM
A-Poc
Sep 8, 2005 02:15 AM
charger 69
May 5, 2005 06:42 PM
herb
Apr 4, 2004 01:39 AM
