Dextron in 01 tranny
Old Apr 15, 2006 | 07:45 PM
BobQ's Avatar
Can I put Dextron in my 01? it calls for +3 but thought the Dextron my help to keep the tc from slipping?
Thanks Bob
Old Apr 15, 2006 | 07:51 PM
GlennRMK's Avatar
Not a good idea IMO. And I'm pretty sure an 01 calls for ATF +4(which is synthetic or synthetic blend).
I would recommend a premium synthetic like Redline or Amsoil.
Old Apr 15, 2006 | 08:33 PM
BobQ's Avatar
The manual calls for atf+3. I double checked. I know the synthetics are better as a general rule, but they also slip more, making for a nice soft shift, I am a little over powered so thought the Dextron may slip less. I hear DTT calls for Dextron just for this reason, so I thought it may help me?
Thanks For the reply!
Bob
Old Apr 15, 2006 | 08:35 PM
rockjeep73's Avatar
it may help a slight amount with the slipping as it is a more agressive fluid, although I dont think it will prevent your converter from slipping if it already slips.
Old Apr 16, 2006 | 09:49 AM
infidel's Avatar
Most of the diesel tranny specialists recommend Dexron plus two tubes of Lubegard black. The Lubegard will make Dex equal to +3 or +4.
More info http://www.lubegard.com/automotive/trans_atf_hfm.html
My stock tranny went 212k on it before I replaced it with a Suncoast.
The Suncoast has 30k miles problem free with Dex plus Lubegard also
Old Apr 16, 2006 | 04:35 PM
DOMAND's Avatar
My 01 calls for +4 on the trans stick. i would check it again.
Old Apr 16, 2006 | 05:41 PM
Cummins4Life's Avatar
My 01 called for +4. When I put in a DTT exchange transmission I switched to cheapo (usually chevron) dexron-mercon and changed it every 10K. Worked great for me. When I had my 94 rebuilt I did the same and so far its working well.
Old Apr 17, 2006 | 10:24 PM
bmoeller's Avatar
My truck had Dexron/Mercon in it when I bought it. The T/C clutch shuddered REALLY bad with it. Not nearly as bad the the +3.
My Goerend tranny has Dexron, plus a bottle of additive.
Metal Twister
13
Dec 22, 2012 10:51 AM
nickg
Jan 17, 2009 10:05 PM
A-Poc
Sep 8, 2005 02:15 AM
charger 69
May 5, 2005 06:42 PM
herb
Apr 4, 2004 01:39 AM
