Power steering capacity
Originally Posted by mini14
just changed mine with valvoline synthetic blend bout 1 qt. used turkey baster
Start the engine... Rock the steering wheel left to right until the pump runs out. about 2-3 seconds...
Then re-fill and do it again... I would do this about 2-3 times to be sure to remove all the old fluid out of the system (gear box, pump, brake booster, etc)
Then re-hook up the hose and refill the system. It will foam up a bit so re-check it in the morning.
It takes about 1-2 quarts to do this... But I got to admit the fluid last a good 30-40K now... Nice clean and clear fluid!
The method above doesn't remove the old fluid out of the brake booster or the gear box. Even if you do this a few time all your doing is diluting your new fluid with the trash that is in your gear box etc... It better to flush it out! In one hole out the other hole...
Originally Posted by BigBlue
Well I'm not gonna worry to much about getting it all out of the steering box seeing as how that's getting replaced.
YFZRidr91
May 22, 2008 08:58 PM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
Bobcat698
Aug 11, 2005 10:10 AM
Of course I'll never let them know they were right.
