Is this possible?
Old Mar 2, 2005 | 12:49 PM
blh1960's Avatar
Is this possible?
A friend of mine owns a 01 2500 Ram with the V10. He has been complainting about the horrendous gas milege. He has the 4:10 gear ratios.
I have the 3:55 gear ratio in my 2500. My question is this...would It be possible to park the trucks together and easily swap the gears out of the two. I would like the 4:10 and he would like 3:55 to help improve his milege. I want pulling power!!! Are the gears the same in the 99 and 01? How long would it take for somebody that knows what their doing?
I am considering this. With 315 tires I think this would be a better gear for me.
What do you think?
Brian
Missouri
Old Mar 2, 2005 | 01:09 PM
high country's Avatar
I cannot tell you if the gear sets are the same but I can tell you that it is quite a job, you will need to set up each of the 4 gearsets in their housings, if you are not equiped for this : press, mics, dial ind, torque wrench in/lbs & ft/lbs, shim and bearing kits, patience, etc. you might as well grab about $600 smackers and head to the gear shop.
On rare occasions you may find the gear sets use the same set ups but tou would still need to set the preloads.....bottom line if they are the same gear sets you are gonna be under the truck for most of a day,
have fun!!
Old Mar 2, 2005 | 01:16 PM
Shovelhead's Avatar
Administrator / Scooter Bum
It might be easier to swap hub to hub rear ends.
Are both drum brakes?
Old Mar 2, 2005 | 01:29 PM
blh1960's Avatar
I would need to swap both (4x4). Lot of work! Maybe it is not such a good idea!
Old Mar 2, 2005 | 06:43 PM
wgingg's Avatar
i swapped out the axel housing. diesel to diesel so im not sure but would think they are the same. we had side by side hoists and knocked the whole thing out in a day.
Dwight
Mar 18, 2003 08:14 PM
wildcard3766
Mar 16, 2003 07:38 AM
AlpineRAM
Mar 10, 2003 05:47 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
TPilaske
Oct 24, 2002 08:24 PM
