P0500 & P1693
Old Feb 6, 2005 | 03:13 PM
KUMMINZ1983's Avatar
P0500 & P1693
Anyone know what these mean? I just did the key trick and this is what pulled up.
Old Feb 6, 2005 | 03:53 PM
Meatball's Avatar
yo
hey man i got the same too its been awhile but the 1693 is a turbo overspeed/overboost (not really a big deal) and the 0500 is just a junk code usually pops up with other codes basically meaningless.
Old Feb 6, 2005 | 04:07 PM
Dr. Evil's Avatar
Re: yo
nope thats not correct...1693 is called a companion code....it just tells you another code has been set.
P0500 has to do with wheelspin or with the ABS sensor on the rear diff. I initially thought the sensor may have went bad - but, I disconnected my batteries for a couple of hours and the 0500 went away by itself.
Old Feb 6, 2005 | 04:10 PM
Meatball's Avatar
oops
sorry mixed up with the companion code and i popped a different number last time
Old Feb 6, 2005 | 06:20 PM
TPilaske's Avatar
P0500: No Vehicle Speed Sensor Signal
No vehicle speed sensor signal detected during road load conditions.
That's what my service manual says anyway....
Tony
Old Feb 6, 2005 | 06:51 PM
Dr. Evil's Avatar
Thanks for the correction Tony....
its not the ABS sensor its the Vehicle Speed Sensor. In any event, it simply disappeared on my truck after I disconnected the batteries..
Old Feb 6, 2005 | 09:10 PM
TPilaske's Avatar
No problem... I didn't realize the service manual had all the codes listed in there until I was just skimming thru it....
I do have about a half dozen codes on mine... don't really bother me much!
Tony
Old Feb 6, 2005 | 09:32 PM
Dr. Evil's Avatar
Tony, whats the code for a Baldwin oil filter???
Old Feb 7, 2005 | 12:58 PM
johnh's Avatar
0500 code
i can get the 0500 code every time by doing a fast idle warm up ( 1200 t0 1500 rpm) also the 1693 companion code.. you can get rid of 0500 by disconnecting the batt`s but not 1693
Old Feb 7, 2005 | 05:13 PM
TPilaske's Avatar
That's too funny...
Old Feb 7, 2005 | 05:52 PM
phox_mulder's Avatar
The P0500 can be thrown anytime the computer thinks the truck should be moving, but it isn't,
or shouldn't be moving, but it is.
such as spinning the tires in snow or mud, extended revving of the engine in park or neutral,
long downhill coast at idle.
Mine was thrown when I got the truespeed, and the wire became unconnected, I also had no speedo or cruise control at the time as well.
phox
Old Jan 8, 2007 | 09:34 PM
Rodram2002's Avatar
I get the P0500 code all the time. reset it and it will come back. the speedo works great. I did have the Truespeed and took it off, but the wire is connected. any ideas? oh, and I haven't lighted up the rear tires as of late.
Old Jan 9, 2007 | 12:40 AM
cLAYH's Avatar
I had the the P0500 code, cleared it twice and it came back right away, did the the APPS calibration and so far its been off for a week.
DieselNomad
Jan 11, 2014 04:56 PM
ted_pulliam
Apr 2, 2009 01:30 PM
dodgediesel
0
Nov 30, 2007 08:43 PM
BigBRUNO4
Feb 18, 2007 10:10 AM
ramtd02
Mar 4, 2006 11:17 PM
