P0336 Error Code
Old Feb 19, 2007 | 05:35 PM
Doug2000's Avatar
P0336 Error Code
If I'm doing this wrong sorry, as this is my first post.
I have a 2000 3500 diesel dually with 56k. It is a longbed quad with auto trans. I have added 4" exhaust, K&N airbox and running the super chip. I just got the above error code. It clears but comes back. I also noticed the first time I got it the rpm gauge fell off and the truck went dead. I get a gen light as well. The only thing I have done recently is put 2 new batteries in. I also found the o2 fuses has somehow come out of the socket so I put it back in and cleared the code....Any ideas would be greatly appreciated....
Old Feb 19, 2007 | 06:17 PM
phox_mulder's Avatar
P0336 Crankshaft Position Sensor Signal
Tachometer gets it's signal from this sensor, PCM uses the signal to let it know the engine is running so it can turn on the alternator (voltage regulator is inside the PCM)
Welcome to the board.
You'll find most of us are pretty knowlegable about these trucks.
phox
Old Feb 19, 2007 | 06:22 PM
Doug2000's Avatar
Thanks for the info...So what can I do to correct the problem. I keeps coming on. Sometimes it shuts the truck off and sometimes it don't...Should I get auto zone to check out the altinator since that light comes on when it happens?
Old Feb 19, 2007 | 06:27 PM
slim51015's Avatar
You'll have to change the sensor.
Old Feb 19, 2007 | 06:42 PM
The only walkthrough I could find is for a '99.
Shouldn't be too much difference, I would think.
http://www.geocities.com/palmerlives...aftSensor.html
or
http://www.dodge-diesel.org/articles/cps/ckp.htm
(from back when we were known as dodge-diesel.org, but still links here)
phox
Old Feb 19, 2007 | 06:49 PM
Doug2000's Avatar
Thanks for the info guys...I'll get that part and changer er out....Great forum by the way....
kzimmer85
NCDTR #18
Feb 23, 2009 02:35 PM
rockcrawler304
Nov 27, 2008 08:56 PM
Howling
May 25, 2008 12:44 PM
JMBryant
Apr 22, 2008 08:04 AM
cquestad
Nov 1, 2004 11:51 AM
