P0336 cam position code
Old May 25, 2008 | 11:50 AM
Howling's Avatar
A friend of mine has a 04.5 with twin pumps,twin chargers,large stix's,camshaft,smarty.It had a TST on it a while back but it has been removed along with the harness.
The truck will pop a P0336 code which is the cam position sensor code and will miss and buck with light throttle.Replace the cam position sensor and seems like all is fine but the later in the day it pops up again.I know the tst will flash this code every now and again but not with the smarty.
Any help would be appreciated.
Eric
__________________
Old May 25, 2008 | 11:59 AM
Spooler's Avatar
Yes, read the above thread.
https://www.dieseltruckresource.com/...ad.php?t=81936
Wire chaffs going over the A/C lines right above the compressor to the High/Low pressure sensor. 5 volts on this line is the same 5 volts that is used for the camshaft position sensor. The wire is grounding out. Throw some electrical tape on the wire and some plastic wire loom and call it a day.
Old May 25, 2008 | 12:44 PM
zuki_dan's Avatar
Mine kept popping the same code, about every three days and took the a/c sensor wires re-wrapped them in tape and put loom on them and it solved the problem.
k9prtnr
Jun 3, 2012 09:16 AM
k9prtnr
0
May 27, 2012 02:28 PM
Two Dogs
Jul 11, 2003 09:12 AM
