P0237 again...
Old May 13, 2007 | 03:23 PM
REDNECK-WELDING's Avatar
P0237 again...
ok i have a 2000 dodge..and i never had any codes..installed the edge comp without tapping it..and for the 1237 code..i know its a low volt code or whatever...is it my map sensor? could it just have been weak before and finaly crapped out? my fuel milage went down lots..i cleaned all the connections..what can i check for? or should i just go get a new map sensor? i also cleaned out both sensors..the check engine light comes off and on...any help please..thanks
Old May 13, 2007 | 10:25 PM
ROADWARRIOR's Avatar
I would make sure your MAP connections are good before you buy a new sensor. If you haven't already, put some dielectric grease on your MAP connections. I had a bad connection in the MAP sensor of the Comp harness give me an intermittent stumble and 0237 code.
Dan
Old May 14, 2007 | 12:42 AM
would this effect my fuel mileage?? did you code come back? is there any more problems with your comp box?
Old May 15, 2007 | 11:34 AM
roadwarrior- thanks for the help...i cleared the code..dissconnected the batt, pulled the map sensor connections..and cleaned up the little prongs on the comps side with a small drill bit..i guess there was corrosion on there that needed to be scraped off ..put some electrical grease in there and put it back together...and the code is gone and hasent come back yet...i cleaned the comp connections before but i needed to scrape it down alittle...thanks again
Old May 17, 2007 | 12:09 AM
ok i spoke too soon...didnt have any code for a few days...cycled the key 3 times non...drove about 3min and it popped back with thte light.....i unpluged the chip and im going to drive it like that for a day or so and see if anything pops up..if it does im going to change the map sensor...if nothing then its something in the chip...also i said i have the comp not tapped..should i move the ground to the battery? or does this not matter....please help im sick of this damm thing
Old May 18, 2007 | 01:20 AM
I don't have my pump wire tapped either.
It is best to have the Comp grounded at the battery.
My problem didn't go away after I cleaned up the connection, the corrosion had already traveled into the Comp wire harness. After I got a replacement harness free of charge, my problem and code went away for good.
Dan
Old May 19, 2007 | 04:44 AM
2 busy's Avatar
I hope you figure out the prob. I'm having the same prob on mine. may go for days or week before it does it. threw it 4 times in one day .
Old May 19, 2007 | 12:28 PM
Dan
mine is grounded to where they say in the manual...how did you get a new harness? i have email edge 3 times and had no responce... also mine came with the truck so i dont have the reciept...i dont think they will replace it for me??
Old May 22, 2007 | 04:48 AM
If you have yours grounded to the airhorn, extend it over to the battery. This was recommended to me straight from Edge. They gave me a new harness after I sent mine in for repair. I called them.
Dan
Old May 27, 2007 | 11:29 PM
ok i will give them a call...mine isnt grounded to the horn i will ground it to the battery anyway...also i hadnt got the code in over a week and i reset my APPS today and threw the code right away....grrrrr.....im sick of this code...i know my map sensor is ok as i pulled my chip and ran it stock and i have no codes..since i pluged the chip in i got it again..
Steven K
Jun 4, 2009 10:32 AM
2 busy
Aug 19, 2007 09:48 AM
b84u
Feb 20, 2006 01:04 PM
kowman
Sep 11, 2005 08:56 AM
Haulin_in_Dixie
Apr 2, 2005 02:20 PM
