oil pressure gauge issues
Old Nov 1, 2009 | 01:45 AM
77machomopar's Avatar
my oil pressure gauge reads 60psi whenever the key is in the run position. when off it reads 0psi. i think its the sender unit but want a second opinion. thanks.
Old Nov 1, 2009 | 06:31 AM
ericg's Avatar
that's where i'd start
Old Nov 1, 2009 | 03:18 PM
SIXSLUG's Avatar
Dodge $400. Napa $315. Kenworth NW $102 for the sender. Since replacing mine the new one is more sensitive and gives a better reading in my opinion.
Mine was doing the same as yours, pegged or nothing.
Kurt
Old Nov 1, 2009 | 05:21 PM
thanks ill be going to the local cummins dealer. tommorrow
Old Nov 1, 2009 | 05:50 PM
RockysInMyBlood's Avatar
When I replaced mine on my 2001.5 this summer, the new one took a different size deep socket than the old, which I didn't have, so it took an extra trip into town ...
Old Nov 1, 2009 | 07:45 PM
ok thanks for the input ill take that in mind when i pick it up
Old Nov 1, 2009 | 07:48 PM
rich's Avatar
seems cheaper to get mechanical one that will give you true readings
Old Nov 1, 2009 | 08:02 PM
yes it probably is. but i want my truck to look like it did from the factory. i like the look of a clean dash, not cluttered with guages. However i am gunna put a temporary pressure gauge in to check it since i jsut got done rebuilding the engine.
Old Nov 6, 2009 | 12:36 PM
SIXSLUG's Avatar
Oh, by the way, the new one looked a little different than the old one, but mine actually took the same socket, I think 1 1/8" deep. Make sure it is a two wire and has the correct end. Also you should write down the CPL ( Control Parts List) number from your engine to make it easier on the parts counter and to make sure you get the right one! I also keep my engine serial # written in the owners manual for such times!
Kurt
Old Nov 8, 2009 | 07:03 PM
my sender is a 3 wire sender not a 2 wire? is that correct?
BoDiesel
Sep 5, 2007 03:01 PM
Matt Lambrech
Jan 28, 2007 04:13 PM
Ripper01
Apr 11, 2006 09:10 PM
streetsmoker
Feb 22, 2006 06:47 PM
