Which oil filter?
Old Jan 13, 2003 | 08:27 PM
mic646's Avatar
Which oil filter?
I am kind of confused on oil filters. I know to use Fleetguard oil filters. What I don’t know is the difference between the Stratapore or the Standard filter. I don’t need to know the tech specs. Just the correct one to use. I only have 6000k miles on her now so I won’t be using synthetic yet. ???
Old Jan 13, 2003 | 08:39 PM
TPilaske's Avatar
Re:Which oil filter?
[glow=red, 2, 300]S T R A T A P O R E ! [/glow]
Old Jan 13, 2003 | 10:19 PM
slimchase's Avatar
I wan't the specs, what is different? I know one was like $5.95 and the other is around $8.50 at Geno's so I assume it must be better but gimme some facts.<br>Chase
Old Jan 13, 2003 | 10:58 PM
TPilaske's Avatar
Unfortunately I can't help you with the specs... I use Baldwin Filters for everything.... ;D Just about everyone else seems to use the fleetguards though, I'm sure one of them could give you the specs! All I know is you want the stratapore! ;D
Tony
Old Jan 13, 2003 | 11:17 PM
Ruralmedic's Avatar
Good question. I'd like to know also. Does the stratapore contain a synthetic fiber filter media? Strata, or to stratify, means to form or arrange in layers. It may just be a different way a cellulose media(which is refined cardboard) is packaged within the filter housing. I know the standard Fleetguard for the Cummins ISB is a cellulose filter, and I've seen one that is a microglass also. <br><br>http://www.scuderiaciriani.com/rx7/oil_filter_study/ provides some valuable info on quite a few oil filter brands. If time and $$$ permit this winter, I'd like to conduct a similar study on the filters specific for the Dodge Cummins application, to see what can't be seen from the outside.
Old Jan 14, 2003 | 12:56 AM
Ruralmedic's Avatar
Ah, a search of the world wide web brings some info from the manufacturer: http://www.fleetguard.com/en/product...ratapore.jhtml<br><br>Yes, it is a synthetic filter media that is layered. But I did not find any specs such as micron removal or percent of efficiency, etc. <br><br>The only other oil filter that I know of that uses synthetic filter media is Mobil1, which retails for about $12 around here.
Old Jan 14, 2003 | 05:44 PM
Stormin_Norman's Avatar
Read this first http://www.dodgeram.info/tsb/2001/09-004-01.htm
Bradleysram
19
May 12, 2009 08:36 AM
buggz
14
Nov 19, 2008 05:55 PM
pete97
22
Oct 10, 2008 11:34 AM
swimmy
Apr 29, 2005 04:56 PM
Ramasaur
Apr 23, 2004 06:31 PM
