Odd behavior, any ideas????
Old Sep 19, 2007 | 04:01 PM
swmnkdinthervr's Avatar
My truck (signature below) is beginning to act up...these are the symptoms: Up hill WOT doesn't accelerate as quickly even runs out of power at about 60-65 mph...begins shuddering a little...climbs a little short of normal boost; 28-29#, used to hit 31#...EGT's are about 900-950 (normal to a little low) and fuel pressure doesn't seem affected at all...
It shudders at WOT on the flat too but seems to accelerate with no other issues...just changed both the fuel filters about a week ago, no shudder then...fuel consumption seems the same. Cruises with no issues at all...
I'm also getting a lopey/uneven idle...
Nobody has an idea?
Old Sep 19, 2007 | 06:21 PM
Mike D's Avatar
Could be a MAP sensor going bad.
Old Sep 19, 2007 | 06:37 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I've been having something simular happening since last week. I'm gonna also pull and clean the IAT. I just replaced my fuel filter two weeks ago, but I think I'm gonna change it agian. I would have thought a MAP sensor going out would cause a code......maybe not. I think I'll pull it and cean it just for the heck of it.
Old Sep 19, 2007 | 07:46 PM
thellums's Avatar
does anyone remember what size it is for the map sensor?
Old Sep 19, 2007 | 09:56 PM
JPR Ram's Avatar
I think it's a 1 1/4" socket.
Old Sep 20, 2007 | 02:10 PM
Seems as though there's little surging going on through the whole RPM range but it's only really noticable at idle ('cause you can see it on the tach) and at RPM above 2000 WOT or hard acceleration...I'll have the codes scanned tonight...
anymore ideas???
Old Sep 20, 2007 | 03:05 PM
jrs_dodge_diesel's Avatar
Something is telling me you aren't pushing as much fuel as you used to. The lower boost and EGT #'s appear to show that. That plus the shuddering/surging and idle issues seem to suggest impending VP44 troubles.
Old Sep 20, 2007 | 06:42 PM
I was beginning to worry about that as well but the new VP44 I put on I'd expect to last a little longer, I more than a little happy to find out it wasn't the VP44!!! I couldn't get any codes 'til I disconnected the "VA" box...but then they weren't indicative of the issue so I got Merv from Merv's Auto Repair to take a ride with his scanner, (he has a 24V near 600 HP) it scanned 0 boost while my gauge showed 18 lbs...it was indeed the "Map Sensor" AKA the "Turbo Boost Sensor"... you guys called it, thanks everyone for all your help!!!
Old Sep 20, 2007 | 06:54 PM
Cool, glad to hear is was something easier than the VP44 (and a lot cheaper too !)
Old Sep 20, 2007 | 06:58 PM
Mike D's Avatar
*takes a bow* j/k
Glad you got it figured out.
Old Sep 20, 2007 | 07:24 PM
Why_Try's Avatar
Darn to late. I would have guessed MAP also...I had the same thing. I replaced the VP, injectors, and sent both boxes out to get reflashed before i decided to try the MAP. Glad to hear you were a little smarter than me.
Old Sep 20, 2007 | 08:34 PM
Whew...that had to be pricey...but hey on the bright side ya got a buch of new parts ya ain't gotta worry about for awhile!
Old Sep 20, 2007 | 08:39 PM
Originally Posted by Mike D
*takes a bow* j/k
I used the suggestions here for directions to look in...
Old Sep 20, 2007 | 09:04 PM
bama's Avatar
my 02model,,,,,the map is 1 1/16 socket,,,,,,,,the iat is 13/16.....deep well............bama
dkinzer
Mar 10, 2008 09:04 PM
jballou
Oct 23, 2007 06:15 PM
RacerX1170
Sep 8, 2005 08:43 PM
jonmurr
Nov 30, 2004 07:28 PM
dkinzer
Aug 16, 2003 01:00 AM
