Noise
Old Apr 29, 2004 | 05:05 PM
Cummnzpowr's Avatar
Question Noise
OK..since i skipped the basics of automotive technology .. ...the last 3,000 miles i have been hearing what "sounds" like a bearing noise from the front passenger side area, could be under the hood, or the wheel bearing not sure.It only sounds off from 35-55mph either with the throttle on or off in gear ,or out of gear, same noise..and it goes away after 60 mph, and nothing under 30 mph.Would a wheel bearing make this noise?Or could it be something under the hood like the A/C gurgling? Thanks!
Old Apr 29, 2004 | 07:48 PM
RCW's Avatar
RCW
The wheel bearings on the 4X4 make pretty distinctive sounds when the begin to fail. The noise will usually get louder on a sharp turn that puts stress on the bearing. The usual worn wheel bearing noise is a clicking and scraping sound that changes pitch as the steering wheel is turned from side to side.
I would suspect the brake "squeaker" that lets you know the lining is too thin is clicking on the disk is the noise maker.
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
Tackdriver
Mar 12, 2003 01:58 PM
powerstrokethis16
Mar 9, 2003 09:40 PM
Jones0027
Oct 22, 2002 07:39 AM
