ATP Wrap Noise Reduction Anyone?
Hey Guys,<br> Has anyone used the ATP wrap noise reduction kit (found at http://atpwrap.com/dodge_ram.htm)? If so, does it really work? While pulling my camper (and the overdrive off) at 2700 RPMS at 70MPH the noise is deafening. After a few hour it drives me and the family crazy.
. Help!
. Help!
Guest
Posts: n/a
Re:ATP Wrap Noise Reduction Anyone?
Mr Jones0027<br><br>Why do you tow in 3rd gear. I've been towing in OD for 284,000 miles. Keep your rpm above 1700-1800 and you'll be just fine. If the trailers pretty heavy- install a Power Edge EZ or a BD Plug in Power and hammer down.
[quote author=BigBlackDodge link=board=5;threadid=6117;start=0#55873 date=1035285881]<br>Mr Jones0027<br><br>Why do you tow in 3rd gear. I've been towing in OD for 284,000 miles. Keep your rpm above 1700-1800 and you'll be just fine. If the trailers pretty heavy- install a Power Edge EZ or a BD Plug in Power and hammer down.<br>[/quote]<br><br>BigBlackDodge,<br> I have an automatic tranny. Whenever I leave the overdrive on (in semi flat country in Southern Illinois with the cruise set at 70mph at 1900rpms) the tranny hunts for gears when going up a hill. :'( When I take the overdrive off, the noise kills us for long trips.
The trailer is about 6250lbs dry weight, loaded over 7500lbs. I don't mind the shifting, as long as it doesn't blow my tranny out (which as we know are prone to go out). Which is why I was thinking about the ATP wrap. If it muffled the noise enough with the overdrive off I'd spring for the $700. If the ATP wrap doesn't work well enough, then why spend the money. :
Anyway, thanks for the input. I appreciate it. Adios.
Socalmat
Apr 6, 2007 02:31 PM
Jones0027
Feb 11, 2003 01:34 PM
