No Tags, where can i find my gear ratio?
Old Mar 31, 2008 | 09:30 PM
leeboy's Avatar
Im about to buy new gears (3:54's), i believe i have 4:10's. ( 2000 rpm at 60 MPH with Automatic) I looked in the Glove compartment, but didnt see a tag. Is there anywhere's else i could check just to be 100% sure i have 4:10's?
Old Mar 31, 2008 | 10:41 PM
Haulin_in_Dixie's Avatar
Under the hood at the front. There is a sticker there. If not, jack up the back, put a chalk mark on the tires and on the drive shaft. Have someone turn the tires. If it is limited slip you will only have to turn one wheel or if it is open gearing you will have to turn both wheels not necessarily at the same time. turn the rear wheels one complete turn, the drive shaft will turn 3 and 1/2 turns if 3.55 or a hare over 4 if it is 4.10.
Old Mar 31, 2008 | 10:50 PM
BigIron70's Avatar
Cummins Guru
Gear ratio is stamped on gears. If your 4X4 you need to change the front gears to match or you'll tear up the transfercase.
Old Apr 1, 2008 | 12:29 AM
mopar-or-no-car's Avatar
I believe there is a tag on the diff. Also you could take your vin number to a dealer and have them print off a spec sheet for your truck.
Old Apr 1, 2008 | 01:36 PM
tx_2500's Avatar
Yeah you have a 4.10 judging from mph/rpm
Old Apr 1, 2008 | 05:58 PM
Unless you can find the numbers on the end of the pinion shaft, counting the turns is the only sure way.
Old Apr 1, 2008 | 06:00 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check inside the glovebox.
There should be a build sticker on the inside of the glovebox door,
Old Apr 1, 2008 | 07:04 PM
WestTN's Avatar
If there is no tag that could mean the gear has been changed. In that event the dealer would be wrong. Just do the driveshaft and wheel check above, and you will have the truth.
Old Apr 1, 2008 | 08:53 PM
leeboy's Avatar
yep........its definately 4:10's by the wheel turning...thanks everyone
Old Apr 2, 2008 | 10:11 AM
Joe Diesel's Avatar
heres a calculator you could've used
http://www.competitiondiesel.com/Phil/bg/
mcolectd
Sep 9, 2013 10:12 PM
Silver Ram
Jul 1, 2010 06:52 AM
quicksilvr
Oct 28, 2008 01:01 AM
bigfish5
13
Oct 11, 2006 02:48 PM
bigfish5
Oct 5, 2006 09:44 PM
