cant find my gear ratio?
i have posted this already, and i was told it was in the glovebox, It is not in there. Is there anywhere else i might find which gear ratio i am running in my truck? It is an 05 2500 auto 4x4?
Also try under the hood or on one of the door panels. Also look at the rear itself it may have a tag on it telling you what the ratio is, the tag will be were the cover is and should be held on by one of the bolts for the cover.
I thought that if it said nothing it has 3.73( standard) if it has 4.10, it would list it as an option and would also be in the glove box. It is one of the two as these are the only ratio's that AAM is curently offering unless you go aftermarket.
actually, it should still show 2000 rpm's at 70mph by the speedo, you are actually traveling faster though because of the bigger tires right? If that is true i have the 3.73s.
The tires and rims are only 5 days old. I did 70 in my truck before the tires and it was at 2250 rpm. So that is what I based my theory on. Right now I have no idea how far off my speedo is. But my ratio is now down to 3.90 with the larger tires.
If yo have stock tires on your truck with an auto tranny. And you do 70 mph on flat land and your rpm's are at 2k. Yes you have the 3.73. The 4.10's are at 2250 rpm. Ps get a RokTech sensor I put mine in tonight. Gives you some nice low end power that will help with Mpg
That's right. Only way it would not be is if you had the computer reprogramed for a different tire size.
mcolectd
09-09-2013 10:12 PM
leeboy
04-02-2008 10:11 AM
bigfish5
10-05-2006 09:44 PM
