no power? need help!!!!!
Old May 21, 2005 | 12:45 PM
lowboy's Avatar
I have a 2001 3500 ho 6spd. 1 month ago dealer installed an inj pump. 3 days ago dealer installed a new lift pump. Truck had no power after inj pump, still doesnt after lp. It used to pull hard after about 1700 on up, but now its just slow all the way. Any ideas?? Dodge says nothing is wrong, but i diss agree. Thanks for your time
Old May 21, 2005 | 01:18 PM
rockwithjason's Avatar
first thing to do is to pull the codes and check the fp.
Old May 21, 2005 | 02:55 PM
lowboy's Avatar
did that none showing
Old May 21, 2005 | 03:16 PM
AlpineRAM's Avatar
Do you have gauges? If yes fuel pressure, boost and EGTs could be very helpful. Something else would be to take the dealer tech with a DRB scanner hooked up for a test drive and monitor the parameters like boost as seen by the ECM to pinpoint the problem.
Did you do an APPS reset? Could be as simple as the PCM only seeing half throttle.
HTH
AlpineRAM
Old May 21, 2005 | 03:54 PM
Boost leak? that would eat up some power. I had 4 small leaks on mine, it sure made a difference when I fixed em.
Old May 21, 2005 | 06:41 PM
lowboy's Avatar
how do you do an apps reset? thanks
Old May 22, 2005 | 03:32 AM
AlpineRAM's Avatar
Instructions:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
HTH
AlpineRAM
Old May 22, 2005 | 09:33 PM
lowboy's Avatar
did the apps reset [thanks AR] still nothing. could it be another bad inj pump due to the bad lp? could the bad lp been to blame for the first inj failure? ive heard they dont last long without it. thanks again for yalls time
Old May 22, 2005 | 10:57 PM
JD farmboy's Avatar
I would make sure it had plenty of boost pressure, I've heard that if the turbo goes out on this engine, they're gutless. Anyway its something worth checking.
bigcat83
Mar 2, 2010 11:15 PM
3500eh
Dec 26, 2006 02:56 PM
BossHogg
13
Aug 25, 2005 06:05 PM
dieselman24
Feb 12, 2004 08:33 PM
rackshakermac
Sep 8, 2003 07:28 PM
