need power power
Old Dec 26, 2006 | 10:30 AM
3500eh's Avatar
need power power
03 ram 3500 lacks power. tried bullydog in moderation and destroyed tranny twice in 3 months. truck just lags without. could i have a sensor wrong with my truck, map sensor or something? i need to go to dealership anyways to get code p0633 off my truck, should i get them to do any scans. should i get another type of chip. i wont use my triple dog anymore. thanks for any suggestions
Old Dec 26, 2006 | 11:11 AM
Smokeman's Avatar
What has your maintenance schedule been? Are your filters clean (fuel and air). Does your truck have any odd symptoms like running rough, white smoke? What kind of loads are you trying to move? What setting were you running your triple dog on to trash the tranny twice in three months? More info is required to help you,
Old Dec 26, 2006 | 11:18 AM
3500eh's Avatar
i bought truck with 140k now have problems at 190k. used bullydog on performance, 2 setting . no bad symptoms, except power. i pull nothing and lots of highway miles. truck ran like this since i bought it. friend has same truck and does laps around me with stock. change filters frequently
Old Dec 26, 2006 | 11:20 AM
Smokeman's Avatar
Get it to a diesel shop you trust and get it checked out.
Old Dec 26, 2006 | 11:22 AM
3500eh's Avatar
thanks $$$
Old Dec 26, 2006 | 11:32 AM
Smokeman's Avatar
Originally Posted by 3500 needs help
thanks $$$
Just trying to help. Good luck.
Old Dec 26, 2006 | 12:24 PM
morkable's Avatar
That code will not be causing your problem. Do you have an excessive amount of smoke? What micron of fuel filter are you using? It sounds like you may have a fuel problem,, maybe a weak injector
Kevin
Old Dec 26, 2006 | 02:56 PM
maddog madden's Avatar
With 190K on it you may want to get an overhead done to adjust your valves.
bigcat83
Mar 2, 2010 11:15 PM
JARHEAD
Feb 25, 2006 11:52 PM
v8440
14
Sep 7, 2005 08:39 PM
PapaPerk
Nov 29, 2004 09:13 PM
