NEWBIE Here!
Old Sep 6, 2007 | 04:59 PM
joeairforce's Avatar
Originally Posted by cb06R1
Thanks guys! that's the info i was looking for! really appriciate it! Between this forum and the other forum im on, im going to have a hard time finding time to drive my truck or motorcycle LOL
Thanks Joe, i was waiting on the answer to that Q:, i didnt want to make the mistake of buying a 35psi guage and be able to turn it up to 37psi or something stock and be out $60. how crappy would that be LOL
No prob I got a 60 psi gauge for the same reason when i bought mine. With my Boost jet i can get it up to about 32 psi so i'm still glad i went with the higher psi gauge
oh yeah, one more quick question and i think i'll be good for now. is there a way i can get the admin to send me an e-mail whenever theres a reply to a thread i've subscribed to? cause my memory is horrible and i just forget if i dont have a reminder
Go to your thread tools and you can set it to send you e-mails when theres a new post
Originally Posted by JPR Ram
Yes, but that's just the stock setting. I have an "adjustable boost elbow" from BD, RV275 injectors, and a Quadzilla XZT+ box and I'm getting anywhere's from 30 to 34 lbs. of boost (depending on conditions). Stock turbo.................
The boost jet in mine gets it to about 32 psi
Old Sep 9, 2007 | 01:22 PM
cb06R1's Avatar
ok, another quick question for you guys .. 4x4 actuator .. is there a fuse or relay that im missing for it? i noticed two vacuum lines running to it from the transfer case. all in all my question is, its not working, are these notorious for going bad? or could it be an electrical problem/vacuum pump problem? TIA
i did a little 4wd wheel spin in the drive way since i noticed the light in the dash wasn't coming on, and the drivers side front tire grabbed .. not sure about the passenger side tire, but the other night i was being retarded and went to turn around in a ditch and almost got stuck! need to get this fixed before winter comes
Old Sep 10, 2007 | 07:19 AM
cb06R1's Avatar
nevermind, i found the answer, probably the vacuum thing ontop the t-case causing the prob. $20-25 fix just a PITA it looks like .. can i gain access to this from atop w/ the shifter removed or drop the tranny/t-case? or just scrape off all the crud so it doesnt drop into the t-case as i just "feel for it"?
Grumpy
Jul 23, 2004 10:49 AM
SSminnow
Apr 9, 2004 07:52 AM
SSminnow
Apr 8, 2004 08:27 AM
Idaho Guy
22
Mar 6, 2004 12:33 PM
mkiv_tt
16
Sep 17, 2003 01:00 PM
