A new noise
Old Jul 28, 2003 | 12:43 PM
ronw's Avatar
A new noise
Hello all,<br><br>I was towing my 5th wheel this weekend, when I came to hill and stepped on it to power up the hill a loud whirring noise started. From that point on any load on the truck and I would get the noise. It is not a high pitched noise like a bearing. I did not seen to have a loss of power and the noise <br>does not track with RPM or speed. Seems to be linked to the load on the engine. It does not make the noise when at idle.<br><br>At first I thought it was the turbo??<br>A friend took a look at it and thought it might be a leak at the exhaust manafold??<br><br>The truck is 99, stock with an auto. I have 87K miles.<br><br>Any Ideas??<br>Any one know if an exhaust leak is covered on the 100k warrenty??<br><br>Thanks,<br>Ron<br><br>
Old Jul 28, 2003 | 01:25 PM
Barney's Avatar
Re:A new noise
An exhaust leak is a possibility. Look for some telltale soot signs.<br><br>Your engine probably doesn't have these manifold bolt retention straps installed. My 98.5 doesn't.<br><br>http://dodgeram.info/tsb/2001/09-002-01.htm<br><br>Another possibility is a slight boost leak at one of the hose clamps. But I would think that would sound different than what you describe. Since your power levels are OK, a boos leak is not likely.<br><br>
Old Jul 28, 2003 | 10:07 PM
AaronT's Avatar
Re:A new noise
Might be your waste gate opening. I have had this happen a couple of times under load pulling the 5er and had to back off to 1900 rpm to get the gate to reset.
Old Jul 29, 2003 | 11:16 AM
ronw's Avatar
Re:A new noise
Found the problem,
The clamp holding the rubber boot between the turbo and the pre-cooler came off. I could not see this from above. But after I crawled under and started looking hard I found it.
Barney, Thanks for the TBS. I had found my bolts loose about a year ago. I did not know the retainer was available.
I'm going to see about getting them put on so it does not happen again.
Every time I post here I learn new stuff, Thanks Ron
Smkn600CTD
May 22, 2012 07:21 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
crashinaz
Mar 30, 2004 02:23 PM
Haulin_in_Dixie
Sep 20, 2003 10:28 PM
swank
May 28, 2003 08:52 AM
