Need tips for pulling the oil pan
Old Apr 25, 2009 | 04:36 PM
Shovelhead's Avatar
Administrator / Scooter Bum
99 3500 2 wheel drive with automatic trans.
Looks like I need to get to the tone ring.
Anyone done this without a vehicle lift?
I have an engine hoist and a bike jack (for the tranny)
Just looking for tips to save time and make it less of a pain.
Old Apr 25, 2009 | 07:52 PM
RAM2940's Avatar
I personally have not done that job, but read that you can lift the motor/trans by removing fan and valve cover then loosen motor mount bolts and lift motor so oil pan can be removed. Or either you have to remove the trans.
Old Jun 25, 2009 | 09:32 PM
jv99CTD's Avatar
have a 99 2500 4x4 and did oil pan swap on my back in the garage loosen motor mounts upper fan shroud and lift with cherry picker just enough room before valve cover hit fire wall
Old Jun 26, 2009 | 12:32 AM
Tate's Avatar
You could also pull the tranny back, and you can slide the oil pan out the back if you remove the engine adapter.
Old Jun 26, 2009 | 12:55 PM
Homestead's Avatar
I personally watched my dealer mechanic do this on my truck. Bear in mind it is a 4x4 but he did say it's the same on 2wd's also.
Remove the fan and shroud, pull the thru bolts on the engine mounts, put a jack on the harmonic balancer and jack the motor as high as needed to remove the pan. Before the pan will come out/off, reach in and remove the oil pump pickup bolts, the pan and the pick up come out together.
He replaced my pan gasket, start to finish in 35 minutes while I stood there the whole time. Granted he had a lift but instead of "jacking" anything up and down with a floor jack, he used the lift and a tall stand to lift the motor by dropping the whole truck.
A month later, I ended up doing the same thing in my shop here at home because the leaking pan gasket was actually a cracked oil pan. I did it with a floor jack, the truck sitting on the floor, start to finish in a little over an hour and a half.
Hope it helps
Jeff
Old Jun 26, 2009 | 09:59 PM
dozer12216's Avatar
What makes you think the crank tone wheel is fubarred??? Very unlikely.
cLAYH
43
Oct 19, 2008 10:54 PM
Topper
18
Feb 22, 2008 02:01 PM
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
ewatts2003
Jun 24, 2006 07:51 AM
