Hard start issue
Old Jun 22, 2009 | 09:45 PM
diggerfan99's Avatar
Hard start issue
Hello, I'm new to the forum and I have noticed a few people with the same problem I have. The problem is, The truck starts well when it is cold but after it is warm it cranks a long time before it starts. I had the VP44 removed and tested as it was still under warrenty. It is fine, I was going to try the crankshaft position sensor next, any help would be appreciated, thanks.
Old Jun 24, 2009 | 04:14 PM
dozer12216's Avatar
it would perhaps be worthwhile to have sensors read with dealers Starscan tool to assure they are in correct range and no fault codes popping up. Check LP pressure under all operating conditions to assure pressure adequate but not excessive. Have the valves ever been adjusted?? Any leaks including weepage???
Old Jun 24, 2009 | 05:34 PM
hard start issue
I have had it hooked up and there are no codes. I have checked for leaks and gone over the fuel system. By the way, I have Fass fuel not the stock lift pump. Every now and then it will start right up even when hot. More times than not it cranks for awile. 175,000 miles no valve adjustment. Still trying to figure this thing out but Crankshaft sensor is the only thing I can think of that may be interfering with fuel timing.
Old Jun 24, 2009 | 07:54 PM
13ALPHA's Avatar
What year is it? I just had this issue. It was after the truck had some old winter fuel in it, but even after that burned out it did it. When it doesn't want to start, try unplugging the Engine Coolant Temp sensor, right by the thermostat, and see if it starts then. Mine would start right up when I did that, so I replaced the ECT sensor and it starts right up now.
Old Jun 24, 2009 | 08:49 PM
hard start issue
I did try that once, and it did start right up. I thought since I had no codes and my temp gauge was working, it was just a quincidence. Did you have codes or temp gauge working?
Old Jun 24, 2009 | 08:50 PM
By the way it is a 1999.
Old Jun 25, 2009 | 11:43 AM
13ALPHA's Avatar
Click on User CP in the upper left and you can fill your signature with truck info.
I had no codes, and the temp gauge worked just fine. But when I unplugged it the truck started right up. So I replaced it anyway, and the truck starts fine now.
THe other procedure I tried, which sort of helped, was calibrating the APPS voltage and doing the reset at the same time. If you search for APPS you can find it.
Old Jun 25, 2009 | 08:09 PM
hard start issue
Thanks alot, I think rather than put the crank position sensor on , I will try the coolant temp sensor first.
Old Jun 25, 2009 | 09:49 PM
nitrousn's Avatar
What are your fuel pressures when its acting up????
Old Jun 25, 2009 | 10:36 PM
I don't have a fuel pressure gauge, but I do have a low fuel warning light, it is not on. The truck is running very well, no misses or anything. When the truck is cold, it will fire right up.
Old Jun 26, 2009 | 12:33 AM
Ruralmedic's Avatar
Sounds like a VP 44 diaphragm issue, hard start in warm weather.
Old Jun 26, 2009 | 03:52 PM
13ALPHA's Avatar
My fuel pressure was fine as well, sat at 16 or so the whole time, but still just replacing the "still working" ECT did the trick. Let us know how it goes.
Old Jun 26, 2009 | 09:03 PM
nitrousn's Avatar
You should invest in a fuel pressure guage. Others have reported intermittant hard starts with high fuel pressure. You have a Fass pump so you should be concerened by the possibility of fuel pressure being to high.
Old Jun 26, 2009 | 11:28 PM
hard start issue
I have been thinking about getting a fuel pressure gauge and problably will soon. I do think I will order the ECT sensor and change it. Its the original so changing it can't hurt. Thanks for the help guys, I'll let you know.
riddle family
33
Feb 5, 2010 04:01 PM
mykal41
May 25, 2008 09:39 PM
DieselBoy20
May 24, 2008 06:16 PM
cwoodall
13
Aug 28, 2007 08:11 PM
Stevie G
Jul 2, 2007 10:31 PM
