need some reassurance
my buddy has an 01 h.o 6spd truck cruzin down the road holding your foot on the skinny in the same spot it will lose power and rpms will drop then all the sudden rpms will pick up again to where they should be and has power again. truck had jammer 4's edge comp, fass 150/150, 5" ehaust and a south bend clutch. (just so you all know wht we are working with.) has no check engine light on or pending codes. injection pump going south 4 winter truck has 80,000 on oe pump. just did a cam shaft position snsr about 2 months ago. thanks for any help
In every case that I've seen, the APPS will throw a code 0121 or 0122. On the other hand I've seen a bad VP and no CEL or codes present. And I say your pumps toast? no, BUT.... What's your fuel pressure?
I would just go ahead and do an APPS reset and see if that helps. Look in the Tech section if you don't know how to do it. Sounds like you probably already know how.
Does it do it consistently?
caffecapri
21
Oct 22, 2007 11:34 PM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
