Need some help, guys!
Old 09-17-2008, 09:01 AM
pull-do's Avatar
Exclamation Need some help, guys!
Guys, I had to evacuate from Hurricane Ike, got about half way to my sons house, and the truck acted up, surging, and no power-------- made it to his house, it would pick up power then go back to lack of power,,,
Anyway, I'm a ways from the house and I need to see if I can get the truck back to the house, hopefully, it's a mess here in Houston,
I pulled the codes and got P 1693 and P 0216, I know the last one is probably the IP, but the first one represents what???
I have limited access to the computer, so if you can help me out, I'll check back later,---- I think maybe the APPS needs cleaning,--- what do ya'll think? If so, where is it, I know it's been posted but I don't have time to look.
Right now when I start the truck, it'll will lope bad up and down, then smooths out then lopes again with unburnt diesel, bad smell,-------again what do you think this could be.
Thanks for the help.
Paul
Old 09-17-2008, 08:06 PM
dozer12216's Avatar
DTC P1693 is fault code in compainion module and think you know 216 is death code for VP44. You need a pump and a lift pump. The LP possiblly caused VP44 failure. You can test lift pump if like, but if haven't replaced in last 6 months it's history. No cleaning of apps, IAT, ground wires or air filter replace will heal. Sorry.
Old 09-17-2008, 08:24 PM
Brokenarrow's Avatar
Yeah sounds like your vp44 went south on you! Better get the truck off the road before it leaves you stranded!
Old 09-19-2008, 11:19 AM
pull-do's Avatar
Thanks for the responses guys, gotta go to work now on the truck.
I'm thinking about pushing the warranty thing on the VP, it's a 01 and I only have 90,000 miles on the truck========
Old 09-19-2008, 12:45 PM
heykw's Avatar
refresh my memory on how to get the codes.
Old 09-19-2008, 04:00 PM
dozer12216's Avatar
Three key cycles on failry quickly and leave on. Codes will show in odometer section and then 'done". Believe 2000 was first year for feature. Older need a reader. Can sometimes find for 40 bucks or so. Performance chips frequentlly have the feature also.
Rambunctious1
15
05-22-2006 03:19 AM
azcwbyteaser
22
04-01-2005 12:01 AM
JKM
03-04-2005 03:33 PM
Krink
12-18-2004 10:14 AM
Quick Reply: Need some help, guys!
